720D electical parts
NYChas
10-12-2005 14:11:04
I went to the locale JD dealer this weekend to get the starter sol. for the pony motor and was told it was no longer avalable. Does anyone know of a replacement. Thanks Charles
NYChas
10-12-2005 19:29:20
 Re: 720D electical parts in reply to NYChas, 10-12-2005 14:11:04
Thanks for all your help.I wasn"t sure about the part since they said it wasn"t avalable anymore and if it was special.A tip to napa is planned now. Thanks again.
Glen in TX
10-12-2005 17:57:33
Charles, It's just a 3 terminal 6V solenoid. Probably $15-$25 at a auto supply. You should have the Delco 1107155 6V starter which uses a Delco # 1119799 Solenoid Switch. Also crossed to a S79 Borg-Warner. Any auto supply should have it or be able to get it crossed from that Delco number. Good luck. That $300+ one is for the big 24V starter NOT for the pony and available aftermarket for about half that too.
F-I-T
10-13-2005 12:30:27
 Re: 720D electical parts in reply to Glen in TX, 10-12-2005 17:57:33
Yes, I missed "the pony" in his description. sorry about that.
Glad the guys got you directed. There ought to be a bunch of different 6 volt solenoids that will work on your tractor. You're just looking for a way to switch that high current with a light-weight wire.
Sounds like an old Ford car!
Frank
Chuck430C
10-12-2005 17:21:40
Go to your local NAPA Parts Store or go online. They sell it in a 6 volt version as original. They must have a problem with their rpicing in that the last one I bought was only about $25.00. Maybe they do not use that "been in the warehouse a long time" excuse for charging 10 times what they should?
F-I-T
10-12-2005 15:04:27
Still has a valid part number on JDParts.com, but I doubt that you'd like the price.
Part Details Part Number: AR11023 Part Price: 339.25 USD On Hand: 0 Check Other Stores Description: SWITCH,SOLENOID
