Decarbonizing
Randalp
10-11-2005 21:01:32
Hi
Can anyone recommend a method of decarbonizing a 3010 Diesel that has hardly been worked hard? I only use it for its loader, and have no way of working it. I know of products for 2-stroke engines that are recommended by the OEM, but how about diesel engines?
Thanks
Randalp
10-13-2005 21:38:54
 Re: Decarbonizing in reply to Randalp , 10-11-2005 21:01:32
Thanks Gents
Randalp
10-13-2005 21:38:38
Thanks Gents
jd b puller
10-13-2005 19:55:44
Ever see a liquid cooled engine with a blown head gasket? The piston that's nice and clean is the one that's blown. Check with some other folks, but I've done this on gas engines...
Get it up to operating temp and start spraying water down the intake throat. 1/4 rubber tubing like you use on freezer line siphoned from a bucket. Change the oil when you're done. It'll spray all kinds of nasty out the exhaust.
parrothead
10-13-2005 06:00:10
The only way that I know of decarbonizing is to get it out and work the pee out of it.
Henry J
10-12-2005 13:18:00
Randal
How do you know it needs decarbonizing. I have never done that in my life but have never owned your model tractor either.
I am one of those old geezers that usually goes by the "if it aint broke dont fix it" theory.
Randalp
10-12-2005 14:08:56
 Re: Decarbonizing in reply to Henry J, 10-12-2005 13:18:00
Henry
I pulled my injectors and found them to be very carboned up on the tips. I"ve heard many a story that suggests a few hard hours on a Dyno will purge "power robbing carbon deposits".
Thats why I"m asking you guys. This is my first Diesel engine....
Thanks
Randal
johnny t
10-12-2005 18:11:23
 Re: Decarbonizing in reply to Randalp, 10-12-2005 14:08:56
try just running diesel fuel conditioner in a few tanks of fuel and some injector clearner should be sufficient. i wouldn't do anything else to it because you might make it start using oil. don't over do on the cleaner. it will wash the oil off the cylinder walls and get you in a heap of trouble
