JD 1530 diesel smokes when started
blambmn
10-11-2005 13:47:01
I just purchased a 1530 diesel. Of course on the days I test drove the tractor, I didn't notice much smoke. The outside temperature was about 70. But now that I have it home, it creates a lot of smoke when first started. The outside temperature is now 30-50 degrees in the mornings. Is it customary for these tractors to smoke a lot when started? Is there something needing adjusting? Am I using poor fuel? I'd appreciate any advice you can give me.
Roy Suomi
10-11-2005 19:38:50
 Re: JD 1530 diesel smokes when started in reply to blambmn, 10-11-2005 13:47:01
Does the engine miss slightly when cold? Even a slight stumble can cause smoke. Is the smoke white? or is it blue? or is it black? If the smoke is white or very light colored , Thats unburned fuel. Maybe an injector leaking or not popping at proper fuel pressure. If so , you need to pull the injectors and have them pop tested at a dealer or fuel injector shop. If the smoke is blue , It's burning oil. If it's black, It's fueling too much
