JD 4010 rear end
dirtjockey
10-11-2005 09:06:52
I have found a JD4010 with the rearend blown out. (That is the description that I recieved from the owner.) I am purchasing the tractor for the rear wheels. The question that goes thru my head is should I consider fixing the old girl? Tractors been parked since 1988, but the engine is not stuck. Supposedly ran good before the rear end meltdown. Is this repair of the rear end fairly straight forward and is it going to be prohibitively expensive? I have been told that you will be hard pressed to even find a 4010 with a 4010 rearend.
Roy Suomi
10-11-2005 19:48:32
 Re: JD 4010 rear end in reply to dirtjockey, 10-11-2005 09:06:52
I'm not real familiar with 4010 , but on industrial tractors [ 300-400-500 ] series there is a smaller intermediate shaft that has been known to break.I have seen a 5010 tear out the side of the case when a ring gear bearing quill failed . It might be worth opening it up to see what happened. You might drain the oil from that section to see if there's junk in the bottom.
