3010 Injector setting
Randalp
10-10-2005 19:31:48
Hi
Can someone tell me the injector pressure setting on a 3010 diesel?
Thanks
Rodney A. Johnson
10-11-2005 08:41:56
 Re: 3010 Injector setting in reply to Randalp , 10-10-2005 19:31:48
According to Service manual, injectors are considered ok from 2400 to 2600 PSI. When overhauling injector, JD manual states injectors should be set to 2600 PSI (allows for longest wear time I suspect).
When I had my injectors redone, the place I took them too wanted to set them to 2500 PSI so I would have better cold starting...I asked them to go to 2600 PSI, as I can plug in the tractor.
Randalp
10-11-2005 20:30:31
 Re: 3010 Injector setting in reply to Rodney A. Johnson, 10-11-2005 08:41:56
Thanks Rodney
Randalp
10-11-2005 20:30:16
Thanks Rodney
