34 D questions
Larry806
10-10-2005 17:27:41
I got it running ( runs very well ) and the rod for the redhead oil pressure leaks very bad. The rod has rusted & pitted also the bore below that the bottom " bell" that pushes it up is pitted. Is there any hope for saving it or should I look for another filter section with the rod in it ? It slings oil at the governor behind the mag coupling , what kind of seal is in there? Thank you for any help
Glen in TX
10-10-2005 21:08:37
 Re: 34 D questions in reply to Larry806, 10-10-2005 17:27:41
Larry, I don't think any of those parts will be available from JD anymore. If you can't find another filter head can always machine a new piston and rod indicator for it. Bore out and sleeve the old bore in filter head to same size with steel or brass sleeve. Sometimes you can get the pits filled and put a oring under the rod but that seldom works to keep it from leaking. The governor uses a felt seal in there inside a retainer against a washer. Here are some parts numbers for those. D1943R Felt Seal, D1942R Retainer, D1944R Washer for oil seal, AD290R Piston w/ indicator rod, D1989R Filterhead. You might try Greg Stephens at theoldtractorcompany.com for these parts.
Larry806
10-11-2005 05:41:50
 Re: 34 D questions in reply to Glen in TX, 10-10-2005 21:08:37
Thank you Glen those part numbers help a lot.
