JD M
Al Epp
10-10-2005 17:09:11
Does anyone know what will cut a tar-like substance in a gas tank? It's on a JD M I'm thinking about buying. Tractor has sat in a barn for 10 years. It had about 3 gallons of gas in the tank. I removed the sediment bowl and had to shove a stick in the hole so the gas would drain. The bottom of the tank has about 1/2 inch of the tar on it. Could someone give me a price range so I could get an idea of what to offer for it. It needs both front tires, one rear wheel, seat cushion, muffler, air breather cap, battery and tool box and both side panels. Engine isn't stuck but don't know if it will run yet. It has rear wheel weights and one front weight. Are rear wheels still available? If so, how much?
hwarrior23
10-13-2005 18:05:50
 Re: JD M in reply to Al Epp, 10-10-2005 17:09:11
original rear rims(wavy rims) are still available from salvaged tractors. They run $250 to $300 each.
Mike M
10-11-2005 06:01:00
On a tank like that I just pour my carb. dip cleaner in it and let it set and rinse it out. You can buy it at most auto parts stores in 1 gallon and 5 gallon buckets.
Roy Suomi
10-10-2005 18:14:45
It should come out with some steam cleaning...Maybe a shot of caustic cleaner to help break it up...
