50 JD Overheating Problem
Chuck McDonald
10-10-2005 13:15:37
Hey,
Recently I have had my 50 overheat a few times. I flushed out the cooling system and changed the thermostat. It would cool off and the thermostat would open up.
Yesterday I was plowing and it overheated again. What else could it be? I was thinking that it couldnt be the head gasket because it doesnt do it all the time. It just seems like the thermostat doesnt open up sometimes, or its building pressure and cant.
Help
Chuck
55 50
10-10-2005 19:26:06
 Re: 50 JD Overheating Problem in reply to Chuck McDonald, 10-10-2005 13:15:37
You made a statement that says "It would cool off and the thermostat would open up". Is that what you mean and is correct? If so the thermostat may have been installed backwards or is bad because when an engine cools, the thermostat should close, not open. When an engine is first started, the thermostat is closed if it's working correctly, then as the block and head coolant warms to the temperature rating of the thermostat, the thermostat opens to allow the warmer coolant to circulate through the radiator to cool it.
Chuck McDonald
10-11-2005 10:21:12
 Re: 50 JD Overheating Problem in reply to 55 50, 10-10-2005 19:26:06
I said that backwards. It seems like it would open up and then cool off.
Anyone have a pic of how it should be installed? I did it just like the other one that came out of it. It had been in there for God knows how many years!
It seems to be heating up much faster than it used to too lately just putting around with no load. It will heat up and overheat.
Chuck
F-I-T
10-11-2005 12:37:11
 Re: 50 JD Overheating Problem in reply to Chuck McDonald, 10-11-2005 10:21:12
third party image
Chuck:
The bulb end of the thermostat will go towards the hot water coming from the engine, so that as it gets warmer the bulb will override the spring and the disk will pull away from the flange allowing coolant to flow. Also, most manufacturers provide a small (1/16" or less) hole in the flange shelf or in the disk to allow air to bleed through, as well as just a small amount of coolant so that when you refill it, no air is trapped. If the hole is not there, you might want to add one.
So, if you mount your in the upper water pipe, the bulb goes towards the block.
It sounds like this could be your problem, as the coolant will have to get very warm in order to get the bulb to open up on the "other side" of the flange. If this were true, it would get really hot, possibly boil over, then the t-stat would open, and it would cool off very quickly as that rush of cooler coolant moves around in one slug. Not good for your castings!
Frank
