oil pressure problems
allen worrell
10-10-2005 12:42:06
just restored a 1939 model H john deere. did not overhaul engine it runs great and no smoke. the oil pressure is low at idle speed is that suppose to be that way? It does not increase much at fast idle,but some. this my first 2 cyl. any informatiom would be appreciated. thanks allen
Mike M
10-10-2005 16:58:00
 Re: oil pressure problems in reply to allen worrell, 10-10-2005 12:42:06
There is a pipe plug on the right hand side kinda under the belt pulley behind this plug you will find an adjustment for the oil pressure it has a large screwdriver slot. Turning it in will increase the pressure.
G/MAN
10-10-2005 13:34:31
What's the definition of low, as checked on a known good mechanical pressure gauge? Two-cylinders don't run a lot of oil pressure anyway - 15-20 psi max.
