1020 Two Stage Clutch
Vinnie
10-10-2005 09:31:26
I'm still doing my homework on this tractor before I buy it. Went to look it over again, it has a two stage clutch. I guess one for the tranny and one for the PTO. There is lever below the seat on the left as seated on the tractor for the PTO. I think this engages and disengages the PTO in conjunction with the clutch. There are also some casted sysmbols further forward on the transmission that appear to have something to do with the PTO, but this tractor does not have that option. What would that option do? Can someone explain the two stages of the clutch and how they work with the PTO and Trans? Which is disengaged at the first stage and which at the bottom of the pedal? Are there any advantages or disadvantages to this system?
Thanks in advance for helping a newbie.
-Vinnie
Dennis in MN
10-10-2005 09:49:22
 Re: 1020 Two Stage Clutch in reply to Vinnie, 10-10-2005 09:31:26
Vinnie,
You are correct that the lever on the left below the seat engages and disengages the rear PTO. A lever forward of that (your tractor does not have) would engage/
disengage a mid PTO. The continuous-running PTO clutch when depressed half way stops forward travel of the tractor but allows the PTO to continue to operate. When the clutch is fully depressed the PTO stops turning. A continuous-running PTO clutch is useful when operating equipment that might require the tractor's forward motion to stop while the PTO continues to turn, e.g. mowing in heavy grass or brush, baling, combining, etc.
Vinnie
10-10-2005 11:24:13
 Re: 1020 Two Stage Clutch in reply to Dennis in MN, 10-10-2005 09:49:22
Thanks Dennis, Its crystal clear now. You must own or have owned one? This one does not have power steering and has considerable play in the wheel. I guess that's to be expected in a 40 year old tractor. From the research I have done on the web, it appears that this model is compatible with several other JD's and parts are reasonably easy found. I think its a 1966 model by the SN, but part of it is illegible and I am not sure if I am reading the whole number. If it is a 5 digit number, I have it right; but if the SN has a leading 1 and the SN is really a 6 digit number, then it would be a 1971 model (I think.)
-Vinnie in Eastern NC
Dennis in MN
10-10-2005 14:08:07
 Re: 1020 Two Stage Clutch in reply to Vinnie, 10-10-2005 11:24:13
Vinnie,
Yes, I own a 1967 1020RU with 1950 original hours.
The serial # is a 6-digit number, and if yours is a 1966 the first digit would be a zero. I have all of the manuals, so if you have any questions before you get manuals of your own just ask.
