435 Charging to high
jdman(MO)
10-10-2005 07:32:31
How to you reduce the charging rate? At full RPM the amps are over 30. Russ
John T
10-10-2005 20:10:10
 Re: 435 Charging to high in reply to jdman(MO), 10-10-2005 07:32:31
If the battery is okay PLUS the Voltage Regulator is okay, it ought to back down in charge AFTER the battery achieves a good charge. I would look at the battery and insure theres electrolyte above all the plates and that no cells exhibit a gray or milky appearance which could indicate a bad cell. Better yet have a batery shop give it a good load test.
NEXT if the battery checks okay but she always stays at max charge, there could be a short or else maybe the Voltage Regulators Field control relay(s) are stuck in the max charge condition. Its possible the relay contacts are stuck/burned shut which a cleaning and light filing might cure, but once the relay contacts have the silver coating removed they wont last long.
Keep an eye on the battery for acid boil over or out gassing if she stays at max charge and if the batterys good then it may be time to replace the VR. Be sure theres no shorts in the wire from the VR's FLD terminal to the Gens Field post and if its NOT a VR or battery problem, the Gens Field wire may be shorted to case causing it to stay in max charge. If the armature is removed you can ohm out the Gens 2 field windings to be sure theres NO SHORTS OR CONTINUITY to the case. Take a look at where the 2 field windings splice and be sure the Field post on the Gen is NOT shorted to case which would also cause max charge.
John T
Bob
10-10-2005 08:20:15
Fitrst, you need to check the voltage.
A battery with a weak cell will refuse to come up to the proper voltage, and will cause the generator to charge it's guts out trying to bring the battery up to the regulator's setpoint voltage.
