JD 4250 3 Point
N. TX Tim
10-09-2005 20:13:15
My friend has a 4250 w/QR and a JD loader. We were unloading some auction items from a trailer today and I noticed that every time he raised or lowered the loader, the 3 Pt w/box blade on it would drop to the ground, then raise back up once he was done moving the loader. The loader has a joystick and is plumbed from near the rockshaft and also to the filter cap (no power beyond block). Any ideas what is causing this...he says it seems like it is getting worse.
Thanks,
Tim
N. TX Tim
10-09-2005 20:37:52
 Correction: JD 4050 in reply to N. TX Tim, 10-09-2005 20:13:15
Must be half asleep...sorry, it is a JD 4050.
Tim
Tx Jim
10-10-2005 03:23:30
 Re: Correction: JD 4050 in reply to N. TX Tim, 10-09-2005 20:37:52
Tim,the control valves,thermal relief valve or piston o-ring must be leaking very badly. Once 3pt is raised other hyd. functions shouldn't affect it. Does rockshaft housing get hot? Tx Jim
N. TX Tim
10-10-2005 06:52:11
 Re: Correction: JD 4050 in reply to Tx Jim, 10-10-2005 03:23:30
Jim,
I don"t know about it getting hot. This was the first and only time I have been around the tractor...and he only had it running a couple minutes. I will have him check though. But from your diagnosis, he is most likely going to have to have the rockshaft cover pulled correct?
Just had this done on my 4430...put in new internal hyd pump (had to get the 4440 kit...ouch, and went through the rockshaft..lots of internal leaks there). That was where my original hyd problems were coming from. Now it is all fixed right...so I can sell it. Bought a beautiful 4450 w/PS along the way and put the 725 loader from the 4430 on it. Took a picture yesterday...will post it later tonight...
Thanks for the info Jim...as always, it is appreciated.
Tim
Tx Jim
10-10-2005 09:13:52
 Re: Correction: JD 4050 in reply to N. TX Tim, 10-10-2005 06:52:11
Tim,if I remember correctly the valves can be serviced without removing RS housing. First thing is to find out what problem is. Tx Jim
