JD G Snap the clutch back tractor still going for
Ben.So.Tex.
10-09-2005 10:34:38
I have put a new clutch in my 49 G, and it has been working fine for the last 4 months or so.. Yesterday I put the tractor in a parade (1st time). Snap the clutch back and I notice that it still wanted to go forward, I could hold it with the brakes but the clutch would start smoking I pulled to the side and I knock it out of gear, I let the rest of the parade go pass me. I snap the clutch a few while waiting, and it felt fine I loaded the tractor with out any problem, I pulled out of the parade because I tought the tractor might not want to stop and injury or kill someone, What could have cause this to happen? I will pull the clutch down later to inspect it. Help me if you can. THANKS BEN
BushogPapa
10-09-2005 16:11:55
 Re: JD G Snap the clutch back tractor still going in reply to Ben.So.Tex., 10-09-2005 10:34:38
You may have replaced the clutch linings, but you don't have all the adjustments made..!!!!
I am not familiar with "G's" specificly, but all the 2-cylinder clutches like the "G" and "A", etc have two adjustable "stop bolts" that need to be adjusted at least once every 25 Years..!!! They screw into the side of the engine crankcase..inside the 1st reduction housing..accessed thry the Huge "Pipe-Plugs" that you will find above and below the clutch pulley.. They should be adjusted to ONLY allow the clutch-fork to travel far enough for the clutch to FULLY release... If it goes any farther, it starts to RE-Engage..! I think this is your problem, unless you have a broken lining that is trying to jam in the clutch.
Mike M
10-09-2005 18:18:07
 Re: JD G Snap the clutch back tractor still going in reply to BushogPapa, 10-09-2005 16:11:55
I think those stop bolts are found on the late 20 series and 30 series ? The early tractors rely on the pulley brake adjustment to stop the lever travel before it pinches that back facing. Also a worn clutch driver splines will only make this condition worse as it moves back on the crank farther makeing that lining pinch quicker.
