4020 injection pump timing advance
Glen Anderson
10-08-2005 22:44:47
I'd like to check to see if the timing advance is working properly on one of 4020s. I've heard of installing a clear inspection window in place of the timing mark access cover to see if the advance mechanism is working properly. I'm assuming I'd be looking to see if the stationary mark(on the cam ring I think??)moves. Could someone elaborate on this a little for me? Also, a little explanation on how the advance mechanism operates would be appreciated. TDC is what the IT manual suggests for timing, does anyone have any experience with any other specs. that work better?
Thanx in advance!
Glen
jdemaris
10-09-2005 07:39:21
 Re: 4020 injection pump timing advance in reply to Glen Anderson, 10-08-2005 22:44:47
First of all, with the initial, i.e. "static" timing, many engines start better when advanced a few degrees. I worked at Deere dealerships when 4020s were new. Some responded well to a one or two degree advance instead of TDC, and cold starting smoking and skipping was greatly decreased. Some machines don't see any benefit. Just try it and see. In regard to the fuel advance, it works off of fuel pressue. The RoosaMaster pumps, either the C,CB or the DB, JDB series, have a small low-pressure fuel pump built into them. The fuel pressure it produces increases with RPMs, and acts on a small hydraulic cylinder that advances the fuel timing as RPMs and sometimes, loads change. To adjust, you put the clear window on the pump - a rectangular window for the DB/JDB pumps and a round window for the C/CB pumps. You then run the engine, and look for the normally staionary line to move a certain amount of degrees depending on RPMs. I have the specs on how many degrees the line should move at given RPMs and/or loads. The adjustment is made via a trimmer screw that faces the outside of the pump and has a 1/4" nut on it that takes a 7/16" wrench. 4020s used C, CB, DB, and JDB pumps. Tell me what pump you have and I'll give you the timing specs.
msb
10-09-2005 12:22:09
 Re: 4020 injection pump timing advance in reply to jdemaris, 10-09-2005 07:39:21
The pump timing works off the transfer pump pressure and against a spring in the timing advance piston which advances or retards the cam ring as JDEMaris points out.The transfer pump pressure needs to be checked for proper specs before the timing should be checked.The transfer pump blades are held against the pump cam liner by very small springs which are subject to wear and failure which will affect the timing curve. A pressure gauge needs to be installed in the test port opposite the fuel inlet.The pressure regulator is inside the fuel inlet and is adjusted with an 1/8" Allen wrench.This is on a model DB pump.If it has been more than 3 or 4 thousand hours since the pump(CB or DB models) has been rebuilt,there is a good chance the transfer pump liner and blades are scored and the spings are needing replaced.A weak transfer pump will affect starting about as much as anything.
jdemaris
10-09-2005 12:50:45
 Re: 4020 injection pump timing advance in reply to msb, 10-09-2005 12:22:09
I tried not to go into too much detail. The transfer pump blades that you mention do not always have springs, the early ones are NOT spring loaded. The later spring-loaded vanes are able to compensate a bit for wear. Also, with the DB and JDB pumps, the fuel-pressure regulator plug blowing out is more of a problem than the vanes becoming non-functional. The early plugs were rubber and Stanadyne provides a metal bushing to replace it (comes in the seal kit).
Also, in reference to aduster-screw for setting transfer pump pressure - it only exists on the later model pumps. Older pumps don't use it and require the changing of end-plate plug to set pressure of which there are nine choices (plain up to number 8).
msb
10-09-2005 20:29:42
 Re: 4020 injection pump timing advance in reply to jdemaris, 10-09-2005 12:50:45
Ah but you are going clear back to the 10 series on the straight blades and the step plugs JDE.All 20 series pumps used the two part blades.I worked in a very busy diesel room for over 10 years.Actually I always found much more scoring of the blades and liners in the spring loaded ones verses the 10 series blades and liners.And I agree, the regulator plug was a problem in a lot of cases.Didn't mean to step on your toes.If I did,I apologize,bob
jdemaris
10-10-2005 06:29:11
 Re: 4020 injection pump timing advance in reply to msb, 10-09-2005 20:29:42
No, your not stepping on my toes. I also worked in a diesel room, we had our own test stand. One nice thing about doing your own pump work and also being the one installing the pump, is getting to see the results. Othewise, as in the case of a pump rebuilding shop, you are kind of isolated. One case in point is the effect of a worn transfer pump (blades and liner) and its actual affect on cold starting. When the Deere 40 series ag. tractors came out, we had miserable problems with cold starting, smoking, skipping, etc. One of Deere's proposed fixes was replacing the transfer pumps in the injection pumps and increasing the advance timimg specs. It all sounded good on paper, but in reality, made NO difference. The real problem was quality control and loose tolerances with machining specs. - especially with valve-in-head depth and piston top standout. We had one case where we had two, brand new 2940 tractors - both supposed to be identical. One started great, down to 20 degrees F with no heat or ether assistance - while the other would barely start at 50 degrees F and when it did, it skipped and smoked something terrible. So, with a Deere engineer present, we started swapping parts between the two tractors in an attempt to make the bad starting tractor start better. We swapped the injection pump, the injectors, the camshaft, the complete cylinder head - all to no avail. We even swapped crankshafts. Finally came to the conclusion that the issue was only the piston standout above deck height.
Glen Anderson
10-11-2005 09:40:56
 Re: 4020 injection pump timing advance in reply to jdemaris, 10-10-2005 06:29:11
Thanx for the replies! I'm still confused about whether the pump receives extra advance while cranking, or is the static timing all the advance that is provided during cranking? With the clear window in place should the stationary line move while cranking or only when running.
Also, what kind of numbers are acceptable for a compression test? That should be good way to discover any problems with valve head depth or any other compression related issues.
Lastly have either of you used a pulse adapter with a timing light to see what the advance actually is?
Thanx in advance!
Glen
HTR
10-11-2005 16:56:35
 Re: 4020 injection pump timing advance in reply to Glen Anderson, 10-11-2005 09:40:56
There is no advance by rotating the cam ring, at cranking speed. However there is advance by what is known as the load advance effect, that is inherent to all Roosamaster rotary pumps.
The top dead center, static timing, is the end of injection. Actual injection starts before top dead center, and this varies depending on the amount of fuel forced into the pumping plungers, by the transfer pump.
Two things to understand about the load advance effect, are, the pump is inlet metering, and the ramps leading to the high part of the lobes, in the cam ring, are inclined. remember The high part of the lobe,is end of injection, static TDC on the 4020.
At slow idle, no load, the metering valve only allows enough fuel to enter the pumping plungers to force them out a very few thousands of an inch. As the rollers, that that force the plungers in, for injection, approach the ramp of the cam lobe, they do not make contact until near the high part of the ramp. This is retarded, load effect, timing.
At high RPM, high load, the metering valve is wide open. This allows transfer pump pressure to force the pumping plungers out as far as they can go. As the plunger rollers approach the ramp, of the lobe, they make contact at beginning of the ramp, and injection starts. This is load advance, advanced timing.
The problem with using the load effect timing only, as they did on the 4010, at high RPM low load, the plungers were only forced out far enough to maintain the RPM. This meant that the plungers were only partially forced out, contacted the ramp later, farther up the ramp, and had the effect of retarding the timing. With the retarded timing, at high RPM, no load, the engine would flutter, from not enough advance. When some power was needed, the governors opened the metering valve, plungers forced out, contacted the ramp sooner, advancing the timing, and the fluttering stopped.
With the speed advance, automatic advance, hydraulic advance, whatever you want to call it, that rotates the cam ring, you have better controlled timing, and a smoother running engine.
With the load advance effect, and the automatic cam turning advance, high load, high RPM, the total advance is in the neighborhood of twenty degrees before top dead center.
There is more to the description of the pump, involving, start delivery, pressure/time, line reduction etc.
jdemaris
10-11-2005 10:58:56
There is no advance at cranking speed. In the case of your 4020, typical settings are: 1 degree advance movement at the window at 375-475 pump RPM (which is 750-950 engine RPM), 5 degrees at 800-900 pump RPM (1600-1800 engine RPM), and 8 degrees at 1200 pump RPM (2400 engine RPM). Note that the degrees and RPMs I just noted are at the pump, not engine and pump runs at half engine speed. So, when actually looking at the lines on the timing window you've installed on the pump (JD259 for a DB or JDB pump), one line movement on the window equals two degrees actual engine advance. The specs. I've given here are for the JDB633AL2721 which is the pump used on the newest 4020s. The earliest 4020 used a CBC633-1AL and nine other pump models were used on the other 4020s. The timing specs. are all pretty much the same for them all. A compression test will not show a valve-too-deep-in-head problem. If you check compression at cranking speed and it's relatively even between cylinders and somewhere in the ballpark of 425-475 PSI, the engine is probably in good shape. Low compression will usually indicate engine damage, e.g. a broken ring, piston, bad valve, etc. It will NOT indicate an out-of-tolerance item such a a valve too deep, or a piston too low, etc. Back to the tests we did at the Deere dealership. We would sometimes have two brand new machines, one a great starter and one a poor starter, the problem was low piston above-deck height, yet they both gave identical compression readings. In regard to using a diesel-pulse adapter, yes I've used one. It usually serves little purpose except in the case of an engine and/or pump that has NO timing marks. I've come across several RoosaMaster pumps with NO marks at all, and in those cases the pulse adapter came in handy. I've got a Case 580CK here right now with a DB Roosamaster pump with no marks on it. In a "real-world" experience rather than what the books say, I've found - with 4020s, if they are not advancing properly, they skip and break up a bit at higher RPMS. If you advance them just enough to smooth things out, they are usually fine. I've had them on the dyno, and seen no performance gains beyond that point of advance.
Glen Anderson
10-11-2005 13:11:15
 Re: 4020 injection pump timing advance in reply to jdemaris, 10-11-2005 10:58:56
Thanx again for the reply!
I'll be getting an inspection window in order to verify if the advance is operating as you mentioned.
In regards to the piston-above-deck height being too low, was planing the top of the deck and re-cutting the counter-bores and option to rectify that problem?
jdemaris
10-11-2005 14:44:11
 Re: 4020 injection pump timing advance in reply to Glen Anderson, 10-11-2005 13:11:15
Initially yes, but that is expensive and sometimes it is hard to find a place to do it. Also, with some tractors, as with the case of the "40" series, especially the 2940, Deere was selling graded pistons from Germany with different standouts. That caused some confusion. Deere finally adressed the issue by increasing the top piston ring height on all the new replacement parts which I believe includes the 4020s. That took place in the late 80s or early 90s as I recall. I think that, more-or-less, fixed most problems involving loose assembly and machining tolerances as they related to cold-starting. If you ever worked on a Volkswagen diesel you'd still find graded pistons and head gaskets. I just had my wife's 91 Jetta apart, and there are three different head gasket options for it - it all depends on the over deck-height of the pistons that are in it. Must be a German engineering thing.
Glen Anderson
10-11-2005 15:58:04
 Re: 4020 injection pump timing advance in reply to jdemaris, 10-11-2005 14:44:11
Thanx for the advice! Yes, it has to be a German thing. Certain Deutz engines I've worked on in the past used shims between the bottom of the air cooled cylinder and the engine block to adjust piston standout. Not totally a bad idea I suppose as it does provide some adjustment, but if they could get their machining tolerances a little closer we wouldn't have to go through those procedures in the first place.
Incidently, I tried advancing up my static timing
by 2-4 degrees and I couldn't say I noticed much less smoke or improved starting but I was rather concerned with the sharpness of the diesel knock
that came with the increased advance so I chickened out and brought it back to TDC. All things considered I probablly need to overhaul the engine more than anything but unfortunately that isn't in the budget(money or time)
Fortunately I've got a great starting system(New 37MT Delco starter, 2 Optima batteries mounted beside the starter with less than a foot of cable between the starter and batteries), 0W30 oil, and a shop to park it in during the winter, so I'll get by till I have time/money to really get into it
Once again, I appreciate all the advice!
Glen
