Gotta see this Tracked JD Tractor not the big T Tr
hooviper
10-08-2005 19:25:42
Super cool 7420 with tracks at www.snowcountrygroomers.com check this site out , do you think you could use it all year around.
CPeter
10-09-2005 16:07:51
 Re: Gotta see this Tracked JD Tractor not the big in reply to hooviper, 10-08-2005 19:25:42
As I understand it, they are steered with a set if hydraulic cylinders between the tractor and the drag. Makes it an articulated machine. Also the brakes help, but they are not made to be used like a crawler or Bombidier so with out the assist from the steering cylinders the brakes would not last very long. On a Bombidier, the differential has a planetary setup on each side that can slow down the track on that side. This is as was told to me by someone who operated a trail groomer built on a big MF.
CPeter
JDknut
10-09-2005 10:28:00
Purpose-built snow groomer tracked vehicles do not work well on bare dirt, they have deep grousers and will throw the tracks. We found that out at my old work where we tried to put a drill rig on a snow groomer tracked vehicle, which my boss got on the cheap. Didn't work, threw the tracks all the time, even when they cut the tracks to half width. It might have worked if they took the metal grousers off the tracks all together, but then it would have had minimal traction and besides, the undercarriage was not built to handle the bigger loads developed on hard ground and it really wasnt heavy enough to carry the drill rig, anyway.
F-I-T
10-08-2005 19:30:34
 Here's the pix in reply to hooviper, 10-08-2005 19:25:42
third party image
NT
Tx Jim
10-09-2005 03:33:10
 steering ???? in reply to F-I-T, 10-08-2005 19:30:34
Is that a rubber tired tractor with tracks added? If so how is it steered? Tx Jim
Terry Hahn
10-09-2005 06:32:26
 Re: steering ???? in reply to Tx Jim, 10-09-2005 03:33:10
Looks to me that you would use the brakes to turn like you would to make a tighter turn normally.
in-too-deep
10-09-2005 08:43:17
 Re: steering ???? in reply to Terry Hahn, 10-09-2005 06:32:26
Well, all the trail corners are banked just right so as the tractor traverses them, it is steered in the proper direction. Okay, not really, but that seems a reasonable explanation.
Glen in TX
10-09-2005 15:10:05
 Re: steering ???? in reply to in-too-deep, 10-09-2005 08:43:17
The tractor still has a differential does it not? I've never drove one with the add on tracks either but they are nothing new and been around a while for combines and silage cutters too. Gilbert & Riplo make a different type.
