How can I get my flywheel to stay tight?
earl p
10-08-2005 16:30:07
I purchased a model 70 gas and found that the flywheel wont stay tight. The splines on the flywheel and crank are worn some but not that bad. Is it possible to shim the splines to keep it tight or are there any other cures short of replacing the crank/flywheel ? Thanks in advance for any help as I have a lot to learn.
lonzo
10-14-2005 22:58:03
 Re: How can I get my flywheel to stay tight? in reply to earl p, 10-08-2005 16:30:07
heat your bolts before you tighetn them and see if that will help, when they cool down it's almost a no can do to loosen
Miller49G
10-09-2005 04:15:05
earl p,
You can get your splines redone to fix the flywheel from moving. If your flywheel splines are wore then the clutch driver splines are wore also. I had my clutch driver splines redone on my John Deere G. They did a realy nice job on them. Look at my web page at the crank I had redone.
Miller49G
DUP
10-08-2005 17:47:32
Install a taper lock flywheeh
Earl p
10-08-2005 18:18:34
 Re: How can I get my flywheel to stay tight? in reply to DUP, 10-08-2005 17:47:32
What is a tapper lock flywheel? Hate to sound dumb but not sure what this is.
Mike M
10-09-2005 07:22:15
 Re: How can I get my flywheel to stay tight? in reply to Earl p, 10-08-2005 18:18:34
Go with a taper lock flywheel ! You may or may not have bad splines on the clutch driver ? These are not directly related except for the fact that whoever owned it before may not of tightened up stuff after working on it. I think the family of the inventer of the taper lock still sells them directly to you. Allen Machine Works ph# 423-753-5738 Basicly your flywheel is remachined to accept a tapered collet that draws up on the worn splines. They were also offering some New fylwheels for some models that were made just for the collet and are stronger than the originals.
