60 cuts out under load
Arthur Driesse
10-08-2005 16:12:22
I have a persistent problem with my 60. When working or accelerating the right hand cylinder cuts out. It has a duplex carb and I believe it is the culprit reason being that when I pull the choke out a bit it seems to work better. So I cleaned every thing out in there also tried adjusting the set screw on the bottom but it does not seem to help. Cleaning it might have helped a wee bit but not enough. They should have kept the single carb of the A. Could anyone help me, Im almost givin up.
lonzo
10-14-2005 23:12:20
 Re: 60 cuts out under load in reply to Arthur Driesse, 10-08-2005 16:12:22
i don't like replaceing parts till it works and then say that must of been it, the condenser can give you fits and so can the coil, there getting old too, trade with somebody who has no problems and see if there parts cure the troubles. i did have a 60 one time that messed with my pea brain, one of the choke butter flys would come loose and knock out one cylinder and i could't see the problem till i remove the carbrater
Mike M
10-09-2005 07:32:39
I once worked on a 60 for someone that had the classic symptoms of a clogged up carb. sputtered under load and ran better with the choke out. They first brought me the carb. after having someone else work on it ,I didn't see anything plugged up ? So after they got everything back together I went to their place and drove the tractor. Sure did act like a fuel problem,but I had brought some points and condenser with me put those in and it went away. So I'd say give it a good tune up including points ,cond.wires with wire in them,plugs,look close at the cap for carbon tracking replace if in doubt.And a compression test and a valve adjustment won't hurt either.Don't foget to set the timing and a cleaning up of all the wire connections going to the coil and switch is always a good idea too.
Mike M
10-09-2005 07:31:31
I once worked on a 60 for someone that had the classic symptoms of a clogged up carb. sputtered under load and ran better with the choke out. They first brought me the carb. after having someone else work on it ,I didn't see anything plugged up ? So after they got everything back together I went to their place and drove the tractor. Sure did act like a fuel problem,but I had brought some points and condenser with me put those in and it went away. So I'd say give it a good tune up including points ,cond.wires with wire in them,plugs,and a compression test and a valve adjustment won't hurt either.Don't foget to set the timing and a cleaning up of all the wire connections going to the coil and switch is always a good idea too.
