4650 won't move in the morning
marsalis
10-07-2005 20:37:36
Any ideas why a 4650 wouldn't move sometimes after it's set overnight? Sometimes it won't move until I rev it up, then it works fine. Doesn't do it every time though.
Glen in TX
10-07-2005 21:34:25
 Re: 4650 won't move in the morning in reply to marsalis, 10-07-2005 20:37:36
Quad-range? Air in the hydraulic clutch causes that. Had a 4450 and it even told about that in operators manual to let it warm up when cold and push the clutch pedal in and out slow once or twice before going into gear. I don't know about power shift but would assume same thing that it just has to circulate and warm oil and get the air out first sometimes before working.
marsalis
10-08-2005 11:53:54
 Re: 4650 won't move in the morning in reply to Glen in TX, 10-07-2005 21:34:25
Yes, it's a quad range. So there's nothing to be done about it? Just live with it?
Glen in TX
10-08-2005 13:14:29
 Re: 4650 won't move in the morning in reply to marsalis, 10-08-2005 11:53:54
If you think it takes too long when warm weather or is an excessive problem check with a JD shop mechanic about it. I just know in the operators manuals for those it does tell you about after starting to push the clutch pedal in and out to actuate it before operating and shifting into gear or to let it warm up more when cold.
