Info on jd B
southpaw
10-07-2005 15:13:21
got my hands on a jd B. Need some info on this tractor. the serial number is 74177. Need to know what year this tractor is. I have a I&T book on jd's the book is dt-4 or jd-4, the book only goes back to 96000 on the serial numbers woold like to have a book on this tractor cause I know nothing about these poppers. Also will any B parts work on this tractor like the head, block, rods,crank ect... Is this tractor with the babbit rods. thanks
Bob Bedlan
10-08-2005 05:52:16
 Re: Info on jd B in reply to southpaw, 10-07-2005 15:13:21
I have a John Deere B unstyled parts catalog.
Serial No.(B1000-B59999)
DickD
10-08-2005 04:15:20
Southpaw; I have redone one of these and sold it, and I have another one I am in the process of redoing presently. The main difference you have to deal with is the hood and fuel tank. The rest of the tractor parts are not too hard to find. I have a good crank for one and probably some other parts if you need them. Unless some one has improvised, your tractor came out with babbited and shimmed rods. If I can be of any help to you, please don't hesitate to email me. It is hard to look at mine and realize today, that we farmed 155 acres with one. When I started around the outside of a 30 acre field we had, I almost had to pitch a tent. lol Good Luck
Pat Cox
10-08-2005 02:55:55
southpaw,
I have a 1939 B, S/N 69203. The I&T book is a good source if you already know what you are doing, but pretty thin if you are just starting. The Operators Manual, Service Manual, and Parts Catalog are all available. They are not cheap, but they are worth the money. You should get the Operators Manual, at least.
Let me know if I can help with part numbers, fluids, ect. as you get things going. There are a number of places to get parts, including Deere.
Good luck!
Pat
amo
10-08-2005 10:31:06
 Re: Info on jd B in reply to Pat Cox, 10-08-2005 02:55:55
you can look to the left of this screen under research & info and find a lot of research you can use. good luckwith your b.
Mike M
10-07-2005 15:31:26
My chart shows 1939 That I&T book is as close as you are going to get. Most of the basic stuff is put together similar so it will help some with tear down. Parts are going to be harder to find as from ser. # 60,000 to 96,000 or 1939 to 1940 used alot of different parts than the ones before or after this. It should have babbit rods.
