1940 John Deere B gas tank
iron horse
10-07-2005 12:54:12
Can someone hook me up with a supplier of gas tanks for a jd 1940 B Either new or Remanufacture
Dont know how bad mine is leaking but gas is to expense to leak at all I am located in the eastern panhandle of West virginia
Skyhawk Greg
10-10-2005 12:48:30
 Re: 1940 John Deere B gas tank in reply to iron horse, 10-07-2005 12:54:12
If you decide to line your gas tank, my personal favorite is a product called POR-15. Second choice would be Redkote. The disadvantage of Redkote is that it is more likely to start drooping within the tank on the larger sized gas tanks. It works fine on smaller tanks such as in motorcycles. The POR-15 people have a package that conatains a caustic cleaner, phosphoric acid treatment, and a final grey colored coating. Type in POR-15 in Google to find out more about it.
Short of using chemicals, the idea of swishing small sections of chain around inside the tank seems to do achieve the best results. However, you will have even more leaks when you are through.
JDVan
10-08-2005 00:10:31
I just parted out a 1939 JD B. The tank was good on it. Contact me at [email protected]
Mike M
10-07-2005 15:40:36
I'd pull out the one you have and see how bad it is . They are pretty easy to solder unless the holes are real big or full of rust. I think that is a hard tank to find as it only fit 2 years.
ironhorse
10-07-2005 15:55:38
 Re: 1940 John Deere B gas tank in reply to Mike M, 10-07-2005 15:40:36
Ok, will give that a try. what do you think of the gas tank sealer that you put in and slosh around?
Mike M
10-07-2005 16:06:04
 Re: 1940 John Deere B gas tank in reply to ironhorse, 10-07-2005 15:55:38
Red kote is a good brand. I like it for pin holes or rusty tanks. I would fix any larger holes or leaking filler necks or the fitting on the bottom where the fuel bowl goes with solder first. I took a tank to a shop once that had a leaking fitting on the bottom they just coated the inside. Well when I put the fuel bowl on it cracked the sealer inside because it was able to wiggle from loose solder and it leaked. So I had to pull it back off and soldered it myself. That was the last time I ever took one to get fixed I do them all myself now.
ironHorse
10-08-2005 07:13:12
 Re: 1940 John Deere B gas tank in reply to Mike M, 10-07-2005 16:06:04
what do you fill the tank with to get the fumes out before you solder> Also could I ask for a step by step for doing the soldering.IE what kind of solder and flux. and prep I have done tourch work just not on Tanks. Also now I got the tank off what the best way to see were it leaks
Thanmks
Mike M
10-08-2005 07:34:57
 Re: 1940 John Deere B gas tank in reply to ironHorse, 10-08-2005 07:13:12
Most of the ones I have done hadn't had gas in them for some time. I usually use a HOT high pressure washer and soap and get them as clean as I can if I detect any gas in them. I sandblast the tank to get it clean and to find more holes. I just use a propane torch and acid core solder seems to fix them right up. Filling the tank with water while fixing seems to be a popular method. I did one once with exhaust NEVER AGAIN this one did kinda pop on me scared the heck out of me I think the exaust was rich and made it go.
Woodie Williams
10-08-2005 10:35:59
 Re: 1940 John Deere B gas tank in reply to Mike M, 10-08-2005 07:34:57
The tank on my 1939B doesn't leak but has a lot of rust in it. I want to clean it out and coat it. Does this tank have baffles in it? A tractor restoration book talks about putting a handfull of small bolts in the tank and rotating it to get the loose rust off before coating. I'd appreciate your thoughts on that.
F-I-T
10-08-2005 15:57:02
 Re: 1940 John Deere B gas tank in reply to Woodie Williams, 10-08-2005 10:35:59
third party image
I've used the small length of chain and rotating it trick, and that does work pretty well. A nice curved end on your power washer is a good cleaning aid as well. On severe ones I start with a filling of hot lye water to remove any organic stuff, old fuel, deposits, etc. (it will even dissolve bird feathers). I have even rigged an electrolysis electrode through the neck and let it cook for a week. No rust at all then. I like to slosh them with phosphoric acid after soldering holes with my old style heat it in a torch flame copper soldering iron. The H3PO4 will convert any remaining red rust to stable black oxide, then after an overnight stay, just rinse out with hot water a few times. If the water is hot enough the majority of the water inside will run out and the warmth will evaporate it just fine. Then the inside has a phosphate coating that inhibits rust You can put it on the outside as well). Last thing I do is rinse it with diesel fuel for long term storage unless it gets a slosh sealer like Red-Kote, though I have not had to slosh one for some time. Once the pinholes are sealed and any patches are soldered on, it's been all right to use with out sealer.
I cleaned the "H" tank in the picture this way.
Frank
Woodie
10-08-2005 17:37:54
 Re: 1940 John Deere B gas tank in reply to F-I-T, 10-08-2005 15:57:02
Frank,
Looks like a new tank after you get through with it. How did you attach the photos?
What concentration of acid do you use and where can it be bought?
What's involved with setting up the electrolysis electrode? Is that it in the lower picture?
Woodie
F-I-T
10-08-2005 18:16:41
 Re: 1940 John Deere B gas tank in reply to Woodie, 10-08-2005 17:37:54
Woodie:
~~How did you attach the photos?
I post them to my photobucket site, then post the url in the "Optional Image URL" slot in this message, and then everytime someone looks at this message, they will see the image I posted on my site. You can poast pictures and link to them by putting them under the "Parts & Pieces" heading on the left side of this page.
~~What concentration of acid do you use and where can it be bought?
It's specifically Phosphoric Acid, and it comes under a variety of names. Ph-Ospho-Ric+ is one available at most Home Depots in the Paint prep section.
~~What's involved with setting up the electrolysis electrode? Is that it in the lower picture?
I have an article on my website that will get you started. Go to www.fboerger.com and look under restoration tips. The wire you see in the lower picture was the lead to a little flashlight lamp so I could get light in the tank so I could take the picture.
Frank
Mike M
10-08-2005 12:16:11
I don't think they have any baffles,but the two tanks are made together. Putting metal objects like bolts washers ,chains does help knock off some loose stuff and then you can get it out with a magnet.Some people even strap them to the wheel of a jacked up tractor and use this to agitate it. I have used THE WORKS toilet bowl cleaner cheap from the dollar store to clean out some smaller tanks with very good results.Cleans it to bare metal,but only trouble is after rinsing it's hard to get them dried without flash rusting again. I have sprayed some moisture displacing lube in them while wet this coated the tank with oil to stop the rust while drying. Then once dry some lacqure thinner cleaned out the oil once that dryed I coated them inside with red kote this seals them up and puts a liner inside so they won't rerust.
