2240 3-point hook-up travel heigth and depth
Leon J
10-07-2005 09:54:51
Just bought a 2240 and the end of the arms on the 3-point hook at its lowest are 20-24 inches above ground level. At its highest point the top of the arms hit the back of the seat. It has only one control lever. Surely there is an adjustment to lower its travel range. I could probably lower it some by unscrewing the arms, but I don"t think there is enough adjustment in it to get it low enough to use a round bale spike. Any help would be appreciated.
Wayne in Pa
10-07-2005 14:24:25
 Re: 2240 3-point hook-up travel heigth and depth in reply to Leon J, 10-07-2005 09:54:51
I'm no expert on a 2240 but I think the top lift arms are put on the rockshaft on the wrong spline. The top lift arms would not touch the seat for a safty reason. Check how the top arms are on the rockshaft and rotate down one spline.
Wayne
Leon J
10-07-2005 17:50:07
 Re: 2240 3-point hook-up travel heigth and depth in reply to Wayne in Pa, 10-07-2005 14:24:25
Wayne, I've got it traveling down now to about 12" and it seems to be about right. I thought about the rockshaft spline thing, hoping that wasn't my problem. I believe that the control lever just got loose and worked to the wrong position. These Southeastern Oklahoma hills and rocks can play tricks on you....ha...I appreciate your suggestion, but I believe I got 'er saucered and blowed now. Thanks again, Leon
Leon J
10-07-2005 13:39:32
I found an adjustment on the lever control and now have it down to 14" above ground level,,,this may be as low as it was intended to go...
