Agri-service harness for 720d
Don Dittmar
10-07-2005 05:20:50
I was looking into buying a new wiring harness for my 720D w/ pony start. Does this harness include the wires that hook to the light switch and amp meter, or how does it come. Does it come with the factory color coded wires?? The section of harness that gors to the generator and fuel level sending unit is ok, but the section of harness for the light/start switch is all bad as is the wires going to the lights. Is it possible to get a wiring diagram that shows how all the switches and gauges are wired in?
Don Dittmar
10-08-2005 05:40:34
 Re: Agri-service harness for 720d...forumn bashing in reply to Don Dittmar, 10-07-2005 05:20:50
I just bought the book Glen recomended from the Deere website. I am partial to Allis Chalmers, but wanted a 2 cyl diesel of my one...hence the 720 was added to my collection. I do have 2 close friends that are Deere guys, so I am sure this book will not only help me, but I will be able to help them in the process. Plus it is something I will always have.....Thanks to all for the great help. I was just in the Allis forumn and there was a long post of people bashing on people.....all over what color tractor is better. Does it really matter??? I thought we were all in this tractor thing together, no matter the color. It is nice to know I can come on this site and there are people willing to help me out when I need it. Thanks to all who have helped me in the past....and will help me in the future
Glen in TX
10-08-2005 13:29:14
 Re: Agri-service harness for 720d...forumn bashing in reply to Don Dittmar, 10-08-2005 05:40:34
I think you'll like the SM2029 manual. I may not have mentioned that it also covers magneto repair and gives specs for generators, starters, & distributors used on JDs of that era. Yeah that bashing stuff goes on all the boards here at times. Makes you wonder if those guys were out sniffing too many fumes when painting a tractor or what? lol. BTW.. Don... use to be a guy in this area of the TX panhandle by your name. That wouldn't be you would it?
Don Dittmar
10-08-2005 04:13:15
 Re: Agri-service harness for 720d in reply to Don Dittmar, 10-07-2005 05:20:50
Thanks for the tips guys. Sounds like the harness is the way to go. I will be to that point soon, so I will be in touch with agri-service in the near future
Jim Guarino, Agri-Service
10-07-2005 16:16:45
Thanks for the endorsements. We also have the lamp socket assembly that plugs into the red jewel on the dash. 720D CE tractors after sn.7214899 (Black Dash) used an oil pressure switch on the cranking engine to operate the indicator lamp. The lamp will glow only when the oil pressure is low on these later models, while the lamp will glow whenever the switch is in the "I" position on the earlier models. SM2029 will show both systems on the same diagram.
Spoker
10-07-2005 12:18:00
jdhbag is correct. I just ordered one for my 720 Standard Diesel, pony start and it cam with every wire except the oil pressure light wire for the pony motor. The wires are numbered like example 1a to terminal bat on ignition switch, which are easy to install. I did have one problem and it was mine. I crossed one wire on a switch and the pony would not turn over. I pulled the dash with harness and layed it out on the bench and took Don's wireing drawing and Deere's and found the one wire I placed on the wrong terminal. It works great if you follow Don's letter. I did find it easier to pull the dash out and wire it on the bench then pull the wires through the rest of the tractor than to try to wire it on the tractor with the dash laying out in your lap and wrastling it around and trying to wire it. He does not has the push button starter button but he told me he might could find on. As it was I took mine apart and cleaned it up and got it to work. Also the fuel button switch. They come apart easy and will clean up and work like new, if they are not burnt up inside. Be careful with the resistor on back of the ignition switch and dont break it off.
Glen in TX
10-07-2005 11:13:50
Don, You should just call them and ask about it. As far as a wiring diagram the JD SM2029 Electrical shop manual will have the 720D wiring diagram in it. It is available on paper or CD from JD Publications. It covers most 2 cyld. JDs and engines of that era but does skip diagrams of a few also. Ask your local dealer and maybe they can copy off one page for you. You can find the manual at JD Bookstore or type in number at JD parts. http://jdparts.deere.com
jdhbag
10-07-2005 07:59:07
i have gotten 3 sets of harnesses from them and they were all color coded with the proper colored wirwes and marked with tags to tell you where they went. Also have a sheet of paper with the wire numbers and color codes listed that tell you where they are supposed to go. Give them a call, tell him what your tractor is and the year and he will tell you waht you need
