2010 Diesel with Low Oil Pressure, Spun Bearing
Robert Cash Mol
10-06-2005 19:42:38
Hi...we got a 2010 diesel a month back. It just had a red oil light on it but we put a regular gauge on it after it spun a bearing and it shows now low oil pressure (5 lbs.). The shop that repaired the spun bearing said it will most likely do that again once it goes back to work unless we fix the oil pressure. Their first suggestion is to put on a high volume oil pump? I'm not a mechanic but would you agree with that or do you think the engine needs more work than that? I think I can order a regular oil pump from John Deere still but not sure about where to get a "high volume" one or if such a thing exists from Deere or anyone if you have suggestions. thank you for any help.
Robert Cash Moline
10-20-2005 08:10:07
 Re: 2010 Diesel with Low Oil Pressure, Spun Bearin in reply to Robert Cash Moline, 10-06-2005 19:42:38
Just wanted to update you that we took the pump over to Deere and they rebuilt it since it couldn't be ordered anymore. Cost $340 and oil pressure is now a pretty good 45 lbs. so we're going to run it today on the brush hog and unless you hear different that worked. Thanks for all your help.
msb
10-07-2005 19:34:08
Low oil pressure is often indicitive of worn cam bearings,if the rod and main bearings are o.k..
BushogPapa
10-06-2005 20:59:19
Use the pump from Mother Deere...!!
Ron..
