JD 1020 Diesel options
Vinnie
10-06-2005 15:30:36
I'm thinking of buying a 1020 diesel, but don't know a lot about it yet. I read a lot of the archived posts and most seemed to have positive words about this model. I'm not sure which options this one has: independent PTO or live, Power steering or manual. I know it has the exhaust turned down and out the back. Does anyone know how common this tractor came with independent PTO and PS or if these were "rare" options to get on this tractor. Any and all info is appreciated.
-Vinnie
jdemaris
10-06-2005 18:01:54
 Re: JD 1020 Diesel options in reply to Vinnie, 10-06-2005 15:30:36
I've got a 1020 and a 300 Industrial. They are virtually the same tractors in different colors. The Ag. 1020 came with some different options then the Industrial 300 did. The German 820 and 830 is pretty much the same also - with a few small variations. 1020 specifically came with manual or power steering, gas or diesel engine (same engines as the 350 crawlers), optional hydraulic hi-lo or reverser, engine driven two-stage clutch that provided live PTO, or engine single clutch connected to an independent hydraulic PTO. Most of the 820s, 830s, and 1020s I've seen have the little German hydraulic pumps in them - the 820s using open-center systems and the 1020s using closed-center systems. I've seen a few 1020s and many 300s with the larger U.S. built 8 piston pumps of 2.4 cubic inches.
