Back firing B
CLK n Cypress
10-06-2005 15:26:46
Have a 47' B ser. # 204*** and spend more time trying to adjust the carb than in the seat. It has to constantly be adjusted. Once the idle mixture is set then it takes forever to get it to run correctly under load (4th. with brakes). Have eliminated the air intake by removeing the A/C to carb tube. Have a gallon tank hanging on the side with fresh gas & inline filter. Sometimes it may idle ok and pop back under load & sometimes it won't idle, work or start. This is my first 2 cylinder and will put into practice any advice. Thanks CK
CLK n Cypress
10-07-2005 07:45:37
 Re: Back firing B in reply to CLK n Cypress, 10-06-2005 15:26:46
Purchased a new carb kit for this problem but couldn't get brass plugs out that holds the float. A friend that has several B's gave me a lesson on the plugs. Cleaned the carb & reassembled with a new float. Still hard to get idle and load adjusted. Have been times as the plugs were being cleaned, I'd turn it over to remove any excess gas in cylinder and it would run fine on just the left bank. So after reading your feedbacks I was maybe in the wrong area. What size plugs are best & correct gap? Also will tune mag to be sure it's right because there's plenty air which are the 3 things for fire. I let you know what I did wrong. Thanks guys for all the help.
Spoker
10-07-2005 13:05:36
 Re: Back firing B in reply to CLK n Cypress, 10-07-2005 07:45:37
First question is do you have Champion Spark plugs in the B. If so Throw them as far away from the tractor as you can get them. Champion plugs will only take 1 flooding with gas and they are toast. Put you some AC's, Motorcraft or Autolite or NGK plugs in the B. Check to see if you have a blue spark from the mag. If not tune the magneto up. Try to clean the points with rubbing alcohol and reset the points. Check your wires to the plugs. One might be firing to ground. I had one on a D that would work fine and then when it warmed up it went to missing and back firing. Found both wires firing to the fuel tank. When you cleaned the carb, did you remove all of the brass plugs and check all the passages? There is one on the idle circuit in the carb behind one brass plug that will stop up and will not let it start or idle correctly. Does the mag have the impulse sould when you turn the engine over? If not the impulse spring is bad or the mag was put on the tractor without the correct endplay on the govenor shaft. Have you checked to see if you are not leaking air around the manifold to the head? This could give you a problem. What shape is the manifold in? They will burn a hole across the divider from the fuel to the exhaust. This will cause a back fire and you can not adjust the carb correctly. It will run but boy it runs very bad. You will not be able to take out the back fire.
Good Luck. This is some things I have run into over the years
CLK n Cypress
10-08-2005 06:38:46
 Re: Back firing B in reply to Spoker, 10-07-2005 13:05:36
Thanks Spoker for all the experiance! Have a kit coming for the mag from JD. My ??? is which plug have you used the most and what's the gap? I don't have any manuals yet or years of experiance as most. This is my first 2 cylinder and appreciate any help or advice. CK
jd b puller
10-08-2005 13:58:41
 Re: Back firing B in reply to CLK n Cypress, 10-08-2005 06:38:46
I use AC C88L - I"d suggest a C87 in your B. Get them at NAPA.
It"s hotter than normal, but not excessive.
CLK n Cypress
10-08-2005 15:05:30
 Re: Back firing B in reply to jd b puller, 10-08-2005 13:58:41
Thanks jd b puller. We will find out as soon as the mag kit comes from Dallas next week. With new plugs, points, condensor & rotor I'll know for sure - - Let you know the out come. Again many thanks, CK.
Grorge S. in the real NY
10-07-2005 05:30:49
Gee, that sounds like the way my '50 B would act. Run OK for a few minutes, then get rough, start backfireing thru carb, and hard to restart. Bought it that way and have chased the problem for the past 3 years. Finally, caught it a few weeks ago. There was a small dent in the carb float and a really small hole at one end of the dent. I did go thru the carb shortly after getting the B. Float looked like a new one. I took carb apart after it had been runing and acting bad, and the float had gas in it. Cooked gas out of float, soldered the hole and problem gone. I think that the hole was so small that it was only a problem when the carb got warm. The times I ran the B in the winter, the problem was not there. Note, if that is your B's problem, check the oil for dilution with gas. Mine was just gas in crankcase and first reduction gear case and it pretty well wore out a new set of rings on the pistons. HTH. George
jdg88
10-07-2005 03:55:44
just a thought my b acted like that. i done everything new carb,points,plugs etc. finally changed the condensor it runs like new.
DW
10-06-2005 22:00:15
Try replacing the plugs. My '50 B will foul the plugs if it idles too much, and then it acts exactly like you are describing yours. Put new plugs in and it runs like new, till it happens again. (my 2 cents worth)
Mike M
10-06-2005 16:06:44
What all else have you done. Have you had the carb. rebuilt ? Have you got good spark ? and New plugs ? It is not normal to have to keep messing with the adjustments.
Connor D
10-06-2005 16:11:41
 Re: Back firing B in reply to Mike M, 10-06-2005 16:06:44
check rocker clearance or maby a bad valve
