G, backfire through carb?
JLG
10-06-2005 15:13:44
My 1950 G is backfiring through the carburetor when I"m trying to start it. I"m assuming this is an ignition timing problem, but if it is, do I need to advance, or retard it? It has a Wico XH magneto that I put new points, and coil in a year ago. If it"s not the timing, what else should I check? I"d appreciate any help. I searched the archieves but I didn"t find too much. I must not have been searching for the right word.
I"ve got hay rides to give Saturday night, and right now I run the battery dead everytime I try to start the old girl! Thanks.
D.J. JD BN
10-06-2005 21:02:16
 Re: G, backfire through carb? in reply to JLG, 10-06-2005 15:13:44
My buddy had a A doing the same thing. It ended up being the mag gasket was riped in one coner and causeing it to ground out now and then when starting it causeing it to backfire. replaced the gasket all works well.
DP
10-06-2005 18:27:01
Does it backfire under a haevy load? If so it could be a sign of burnt valves. BTDT Don
Glen in TX
10-06-2005 18:20:00
You said "If it's not the timing" so.... I assume you checked the timing again? Have it timed right, with top wire on cap to LH #1 cylinder and lower wire to RH cyld. Did someone switch the wires? If timing could be off 180 degrees switch the wires and try it. Points should be clean and set at .015" . Do you have good blue spark? Try switching condensers. Is the impulse snapping well? Carb still set right? Dig deeper and let us know more.
JLG
10-07-2005 05:49:43
 Re: G, backfire through carb? in reply to Glen in TX, 10-06-2005 18:20:00
When I get it running, it runs good. It'll miss when a load first gets put on it, but smoothes out and lugs great. The mag snaps like it's supposed to and I have a blue spark at the spark plug. What I meant before was, I assume I need to adjust my timing and wondered if this was right and which way to go? But if it doesn't sound like a timing problem, what should I check next? Sorry, I didnt write it so clearly the first time. I initially had it set so the mag snapped when the LH IMPULSE mark on the flywheel lined up with the mark on the side of the tractor. But I've rotated the mag both ways slightly seeing if it helped it start easier and didnt seem to be getting anywhere, so now it's a little off of those initial timing marks. I wanted to get on here and see what other people said before I did anything else. I'll make sure the carbs still set right, and I'll check the point gap, and the plug wires too. There's no reason they should have gotten switched. But that doesn't mean it didn't happen. Thanks for the input.
Glen in TX
10-07-2005 10:14:08
 Re: G, backfire through carb? in reply to JLG, 10-07-2005 05:49:43
JLG, I just understood you were having starting problems with battery running down but maybe something else too? You may have to just pull the mag and go thru the timing procedure to make sure it's right and get it to start good and then go from there trouble shooting more things like fuel or intake air problems too. You might want to check cam timing and valves settings too. Search back and find Duane Larson's timing procedure too if still having troubles. Make sure the mag impulse stop plate hasn't slipped or moved too. If a XH-1042 with 6274 drive cup the mark needs to be over to the left of center about 4 1/2 marks and if other drive cup or XH 477 about 2 1/2 marks for the lag angle to be close to 25 degrees for running on gasoline.
