420 VALVES
FDBYRD
10-06-2005 09:45:53
I NEED I SET OF VALVES FOR MY 420. THE ONLY ONES I CAN FIND ARE FROM DEERE & THEY WANT $120 FOR THE 4 OF THEM. ANY ONE KNOW OF A CHEAPER SOURCE?
Glen Anderson
10-12-2005 15:02:13
 Re: 420 VALVES in reply to FDBYRD, 10-06-2005 09:45:53
As Glen in TX said an engine machine shop would be a good place to look for your valves. Quite often certain engines which are common will utilize the same valves as other engines which are oddball or expensive, the best way would be to take your original valves to the machine shop so they can get the dimensions and if you happen to get an ambitious partsman you might get lucky.
Good luck!
Henry J
10-06-2005 10:46:42
FD
I assume that you will use a machine shop for the head work. Any one worth its salt can get the valves. However I don't know what the cost comparison will be.
Bob
10-06-2005 10:31:00
I don't thingk nowadays, that $30.00 each for valves is out of reason, especially for an oddball like a 420.
At least nothing compared to the "sticker shock" I got the other day, when I was going to order a new wobble-box casting for a "450" sickle mower.
There really isn't much to the part, and it is a common repair item for that mower. I figured, on the high side, $300 to $400.00. Actual price, $850!!!!! !!!!! OUCH!!!!! !!!!!
Glen in TX
10-06-2005 11:20:01
 Re: 420 VALVES in reply to Bob, 10-06-2005 10:31:00
Yeah $30 each for those valves may be cheap. Try justifying $115 to $120 each for valves for the Model D !!
Glen in TX
10-06-2005 10:01:51
What is the part number? A machine shop can probably get them for you.
