466 in a 4030
BAD ATTITUDE
10-06-2005 05:18:12
Will a 466 motor from a 4840 bolt into a 4030 without any major modifications
Thank you
WTW
10-06-2005 07:49:23
 Re: 466 in a 4030 in reply to BAD ATTITUDE, 10-06-2005 05:18:12
I will give you a heads up on your inquiry as I have a 4030 that I pull and have pulled the past 7 years. First most important thing to know is you can build more HP with a Dubuque engine than the transmission will take let alone the bigger Waterloo engine. My tractor has had custom shafts installed in it and it sets in the shed right now for the third time with transmission failed. I have completely stripped all the teeth off D range gear, broken teeth from ring gear to break transmission shafts in half in it. So if you are going to do it better plan on a complete custom gearbox as the original stock one will not take it. Been there done that! Next problem is there is no one building a custom transmission for the small case the 4030 uses. You can buy them for the 4010 and 4020 cases but not the small case tractors. The 4030 transmission is nothing more than a 3020 or 2510 size transmission and all three share many common parts. To answer your question yes the 466 engine could be bolted in the 4030 with some mods. One mod would be different frame rails and a 4230 hood. As frame rails will be required to bolt to Waterloo engine and hood will be needed to match the longer frame rails. If you want more or complete information on doing this I can give it to you but remember what I said about the transmission, I hate to be the one to say, "I told you so!" Good Luck, DW
