JD 55 Combine
wardvan1
10-06-2005 03:58:04
Can some one tell me what kind of hydro system the 55 ran: i. e., high pressure/low pressure. Looking to use controls and cylinders off 55 to convert a loader on AC to full hydrualic. AC runs high pressure (up to 3000 psi, low volume system). Wondering if the JD parts will withstand that kind of pressure?
Thanks in advance.
Leroy
10-09-2005 07:19:25
 Re: JD 55 Combine in reply to wardvan1, 10-06-2005 03:58:04
A square back 55 should be the same as a 45 square back in that the hydrolic's had a 2 section pump with one section working the header and ground drive control cylinder; double action; and real lift; single action; ant the header was single action with a pressure activated valve in control so that unless the engine was running you could not lower the header as a safty, and the sectioned side of the pump was for the hydrostatic power stearing; no mechanical link to rear axle, only hydrolic power with 2 way cylinder
msb
10-06-2005 19:18:26
55 combines used a low pressure system.I believe the steering was 1250psi and the rest of the machine operated at a max. of 1500 psi.It was an open center system so it only built enough pressure to overcome the load.The variable speed cylinder and valve was 2 way .
55 50
10-06-2005 08:33:15
I don't know any thing about the pressure. But the 55 we had was only one-way cylinders- UP. The downward action was caused by the weight of the header so I don't think that would work for a hydraulic loader. Now this was a very early 55 so maybe the later ones had 2 way hydraulics.
Handsome Jim
10-06-2005 18:17:28
 Re: JD 55 Combine in reply to 55 50, 10-06-2005 08:33:15
Our 55 was a 69 model and you had to have working hydraulics to lower the header. If the header was in the raised position with the engine not running, you couldn't lower it.HJ
wardvan1
10-06-2005 09:53:10
You're right on the header. However, I was looking at one my neighbor is junking out and the belt "tentioner" is a two way cylinder just about the right size for a bucket dump adaptation.
AJmn
10-15-2005 13:52:04
 Re: JD 55 Combine in reply to wardvan1, 10-06-2005 09:53:10
That "belt tensioner" you are looking at is actually a variable speed belt drive. That small hydraulic cylinder just moves the sheave to change the drive ratio. That cylinder moves quite slowly if I recall right. Probably fed through a small orfice? I don't know.
55 50
10-06-2005 11:48:51
Our 55 was early enough that it had the manual (grunt!, grunt!) ground speed control so I'm no help on the hydraulic there.
