4020 steel hydro lines..replace with rubber?
Nylon
10-05-2005 14:36:21
I was thinking about making that check valve replacement/ repair that had been posted. It involved drilling out the elbow and tapping it and building a seat / ball / spring check into the elbow. Would it not be a whole lot easier to take off the steel line that leads to the hi pressure pump from the tractor split coupler down to the hydro filter cap and have a hose made and stick in a check assembly? Premade checks would seem more reliable and I don't have the equipment or time to drill and tap. Any problem with a rubber hose in that position?
Thanks,
John
HTR
10-05-2005 17:54:46
 Re: 4020 steel hydro lines..replace with rubber? in reply to Nylon, 10-05-2005 14:36:21
Putting the check valve in the line would prevent the oil cooler and pump from draining back to sump, when the engine is not ruining. It would not prevent return oil form being forced back through the transmission pump,to sump, when the clutch peddle is pushed down, and the transmission pump is not turning.
I prefer to remove the rockshaft housing, and repair the valve. Usually nothing wrong with the valve, just the seat in the end of the pipe.
Nylon
10-06-2005 00:02:23
 Re: 4020 steel hydro lines..replace with rubber? in reply to HTR, 10-05-2005 17:54:46
Htr,
How tough is it to get at that valve in rockshaft? GeraldJ said it took a small crane and I thought a tractor split? I have a stolper cab. Do I have to pull the seat and the rear tin to get that rockshaft cover off? Any special tools required to change out the seat? I suppose freshen up the ball too? Spring?
Thanks,
John
Mike M
10-05-2005 15:47:59
I would try your tractor first and see if you really need it. My dealer told me about a check valve update that sounds kinda like you described. My tractor is an early 4020 I have not had too much trouble so I never tried the modification. Just start the engine with your foot off the clutch let it run awhile then start cycling the hyd. it will get the air out and come to life.
