Hydraulic oil replacement-520
Randy G.
10-05-2005 10:23:23
What type/ weight oil should I refill the hydraulic tank with?? I"ve heard 30w non detergent, JD hygaurd and the opps manual says 20w-20 oil. Pease advise, its drained and ready to fill. (i"ve never used the hydraulics on this 520 and would like to) Also, what weight /type should the pto housing be filled with?? Thanks for your expert advise!!
Mike M
10-05-2005 10:37:02
 Re: Hydraulic oil replacement-520 in reply to Randy G., 10-05-2005 10:23:23
If it's the only tractor you have it may not really matter,but I have several and a few newer ones around from time to time so I allready have JD Hy-Gard around so I use this in the PTO and hyd. And if for some reason I'd ever hook up a hyd. cyl. they would all have the same oil and not mix it up. Hy-Gard is a really good oil hard to go wrong with it.I even used it in the fan motor on a dehumidifier lasted longer between oilings than other oils I tried.
8e3k0
10-05-2005 12:53:08
 Re: Hydraulic oil replacement-520 in reply to Mike M, 10-05-2005 10:37:02
I agree with Mike; we do the same with all our restored and work tractors that are two cylinders. We use the new hygard hyraulic/transmission oil in the power trol and pto pump/clutches. This then works well when using hydraulic cylnders on various tractors; no cross contamination to different systems because the same oil is used throughout.
