Model B slant dash worth?
anthony kretowi
10-04-2005 19:40:26
Am curious as to the approximate value of a restored 1940 slant dash model B with no electrics at all. Any input is appreciated.
JDVan
10-05-2005 20:16:08
 Re: Model B slant dash worth? in reply to anthony kretowicz, 10-04-2005 19:40:26
I've given your question a little more thought. It may be possible that you have a Slant Dash B that had the lighting only option from the factory which has been removed over time. Then there would not be a starting ring on the flywheel so now the tractor looks bare. I sure would like to see some pictures of this B and find out the serial number. I own two 1940 Slant Dash B's.
anthony kretowicz
10-06-2005 03:23:12
 Re: Model B slant dash worth? in reply to JDVan, 10-05-2005 20:16:08
the serial # is 84783, and I have put some pics of her on the tractor photos area of this site. If this tractor had electrics, then the fan shaft was also changed in its liftime because there is no pulley on it. Nothing in the battery box, either. I have many more photos if you need them. Thanks
Mike M
10-06-2005 05:47:57
 Re: Model B slant dash worth? in reply to anthony kretowicz, 10-06-2005 03:23:12
Does it still have the rubber hub mounted fan ? If so then the pulley that fits on these is a 2 piece unit that you can unbolt and remove fairly easy. Hard telling what the history of this old iron is.
JDVan
10-05-2005 18:37:48
A 1940 Slant Dash B w/o electrics at all is a mis-configured B. The 1939 and 1940 Slant Dash version B from the factory either had Electric Lights or Electric Starting or both.
So it's really not a Slant Dash technically.
