4230 intermittant electrical problem
R. John Johnson
10-04-2005 19:20:51
I've been loosing power to the fan, cigarette lighter ,radio and a bale carrier control box wired into the top rear circuit breaker. The lights and guages still work. It usually happens within a minute of starting the engine. The first two times a sharp rap on the side of the console near the circuit breakers restored the power(I know, not very scientific, but I was in a hurry and it worked). Tonight I went to unload the bale carrier and the power went out. The sharp rap repair method did not work. I tried turning the key on and off, but this did not help.
Drove it to the buildings and just as I was shutting the engine off, the last possible second just as the engine died, the power came back on. Started the engine back up and the electrical seemed fine. It was to dark to start to trouble shoot, but is there anywhere in particular I should look or is most likely a loose connection?
Thanks
John
Bob
10-04-2005 19:38:22
 Re: 4230 intermittant electrical problem in reply to R. John Johnson, 10-04-2005 19:20:51
Replace the relay that powers up the buss bar 1/2 of the breakers are connected to, when you turn on the key. It's key # 23 in the link below. Deere part # AR46334.
Be sure to tight ALL connections on the 2 buss bars.
R. John Johnson
10-05-2005 06:31:21
 Re: 4230 intermittant electrical problem in reply to Bob, 10-04-2005 19:38:22
Bob
I was suspicious of something in that area. The operator's manuals shows the 3 circuit breakers on the rear side of the buss bars control all the items that go out. I will carry some tools and a multi-meter with me today. If the problem re-occurs, maybe I can pin point it. Thanks
John
Bob
10-05-2005 08:58:12
 Re: 4230 intermittant electrical problem in reply to R. John Johnson, 10-05-2005 06:31:21
Carry a jumper wire, and when you lose power, jumper across the 2 large studs on the solenoid I mentioned an see if power is restored. A light jumper wire won't carry the load for a very long time, though, but will work for testing.
It is quite common for that relay to fail, and act as you describe.
If you need to replace it, get the Deere relay, or an acceptable substitute. It is a continous-duty relay, and if a starter solenoid is used to replace it, it will get hot after a while, and fry it's coil.
lonzo
10-04-2005 19:32:09
inside cab on right front corner where the little door is remove the panel under the matt, there is wires that feed the cab under there that can give you fits, you can check buy reaching under there and shaking them around and see if they make things mess up, try it frist before you do anything else
