2010 engine
Steve Gr
10-04-2005 19:17:16
I have a 2010 diesel and the engine is tired. I would like to swap the engine out and put in a different one perferably a gas one. Did John Deere use this engine in anything beside tractors and crawlers, such as combine and haybines and if so what models. Thanks for any info.
Jay B
10-06-2005 12:49:09
 Re: 2010 engine in reply to Steve Gr, 10-04-2005 19:17:16
Steve, If you find a good gas engine I may be interested in your tired diesel. Let me know, thanks.
msb
10-05-2005 18:39:50
Switching to a combine engine is the easy part.Finding a governor and throttle linkage will be a nightmare unless you can find a junked out 2010 gas tractor.
msb
10-05-2005 18:39:45
Leroy
10-05-2005 02:48:10
HC 145 G from late roundback 45 combine and there were several other different versions of that engine depending on application
Leroy
10-05-2005 02:51:46
 Re: 2010 engine in reply to Leroy, 10-05-2005 02:48:10
Just sent that and happened to think, the 165 engine from the early square back looks identical to the 145 with I think just a larger bore deck plate and pistons
Peddler
10-11-2005 13:11:04
 Re: 2010 engine in reply to Leroy, 10-05-2005 02:51:46
Not sure what problems you are having W/2010 JD engine. Its an easy engine to rebuild, although I haven't rebuilt one in 20 years. A rebuild would seem to me the easy path to follow.
