Hello J.John or John A....4230 Question
txgrn
10-04-2005 17:34:07
Ok guys. I now understand the "hootus" on the dash is for ether and there is a line connected to the intake manifold.
I assume you pop the cover and a special JD can of ether twist locks on where the cover came off. I assume it remains there till empty, not attached and removed as needed.
Does this special can have a squirt button also? If not how do you "goose the moose"?
Since you are in a cab environment, would be good to have no leaks, right?
Thanks,
Mark
R. John Johnson
10-04-2005 19:27:26
 Re: Hello J.John or John A....4230 Question in reply to txgrn, 10-04-2005 17:34:07
Mark
Does your's have a block heater? Just a short time plugged in should warm everything up enough to start at this time of the year. That's what I am doing right now. Overnight temps here are getting close to freezing. Quite the day today. Hauled hay, fed hay, raked hay and then baled hay. Take care
John
txgrn
10-06-2005 03:06:35
 Re: Hello J.John or John A....4230 Question in reply to R. John Johnson, 10-04-2005 19:27:26
No. These are Texas tractors and don't have one. Most of the time, with the battery setup I have I can start either the 4010 or the 4230 in the winter. On the really cold days is when I need the help.
Thanks,
Mark
Bob
10-04-2005 18:00:12
1.) Remove knurled cap from "hootus".
2.) Take ether can, remove protective top and spray nozzle.
3.) While cranking engine, push topless ether can up into the "hootus" to blast a short burst into the intake manifold.
4.) Put protective cap back on ether can, and set it in a safe place in the cab. (NOTE... letting the ether can roll around under the seat until you hit a big bump and the seat mechanism punctures the ether can is NOT safe.) Put the protective cap back on the "hootus".
5.) Try to stay awake and operate the tractor in a safe manner, while breathing the residual ether fumes!
txgrn
10-06-2005 03:03:31
 Re: Hello J.John or John A....4230 Question in reply to Bob, 10-04-2005 18:00:12
Had to appreciate your humor. Thanks for the info.
One more question. Is this a special JD ether can or just any old can will fit.....the hootus? Grin.
Mark
msb
10-04-2005 18:55:43
Listen to the man.Bob is one sharp cookie,but I will give you a tip on safely storing the either can in a cab.Set it inside a roll of duct tape placed to the right of the seat.It won't move.The edges of the tape will hold it in place.DUCT TAPE! Don't leave home without it!Its the modern day version of baling wire!lol,another bob
txgrn
10-06-2005 03:04:36
 Re: Hello J.John or John A....4230 Question in reply to msb, 10-04-2005 18:55:43
I use it for other things all the time. Thanks,
Mark
