JD 4010 Diesel - Oil in water
RFox
10-04-2005 14:48:54
What does it mean if there appears to be motor oil in the radiator of JD 4010 Diesel? Is it something where I should not run it anymore? or can I get some more life out of it? I only use the tractor less than 100 hours a year. I mainly notice the oil on the radiator cap and in one of the radiator hoses. The tractor starts really good, has plenty of power but has some light smoke when under a load and the oil goes somewhere or burns, appears to be quite a bit of blow by from the cooler pipe, but not through exhaust. Otherwise its a nice straight tractor, new clutch and Oh'd tranny, great hydraulics.
msb
10-04-2005 18:46:02
 Re: JD 4010 Diesel - Oil in water in reply to RFox, 10-04-2005 14:48:54
I would pull the oil cooler and have a look.Its possible the problem is only a gasket.I wouldn't let it go too long.You need to get the oil out of the cooling system.I would use a mild lye solution after fixing the leak.
RFox
10-05-2005 06:38:11
 Re: JD 4010 Diesel - Oil in water in reply to msb, 10-04-2005 18:46:02
Do you mean the cylindrical deal on the left hand side of the tractor?
Thanks!
msb
10-05-2005 18:45:44
 Re: JD 4010 Diesel - Oil in water in reply to RFox, 10-05-2005 06:38:11
Yep, the cylindrical deal except it is on the right side of the engine as you sit in the seat.
