Bat wing cutter hp required?
Jason Z in MO
10-04-2005 09:01:48
I have a JD 1518 batwing cutter which I pull with a 4020.
A friend wants to borrow it and pull it behind a JD 5310, rated at 65 hp. Is that enough tractor?
Will the drawbar support the cutter?
jddriver
10-04-2005 18:12:19
 Re: Bat wing cutter hp required? in reply to Jason Z in MO, 10-04-2005 09:01:48
I have put almost 2000 acres thru a 15 ft woods behind my 70 diesel and 7.5 ft behind my sons D.Some of this stuff is over 12 ft tall and I have to go in 1st gear.I have gotten mt customer(all repeat) trained that when the material is 2 ft tall they need it mowed.Steve
pbutler
10-04-2005 09:23:17
Drawbar will be fine.
Depends on what he is cutting-if just shorter grass or previously groomed ditches may be ok.
I pull a 7ft-JD709 with a 52hp Massey Ferguson and when I get into tall stuff or brush that 7ft is all it wants.
