Cylinder head alignment on four cylinder diesel
Bob Santilla
10-04-2005 07:44:51
Hello,
I recently rebuilt the four cylinder 202 C.I. diesel engine in my 400 series John Deere backhoe. It uses the same engine as found in the 2020 Ag. tractors. My question is; after removal of the cylinder head from the engine block there are two pins on that deck. Are these pin for alignment of the head gasket only? I ask this because the holes in the head are much larger so these two pins serve no purpose in alignment of the head with the head gasket or the block.
Thanks,
Bob
Jonathan in MA
10-04-2005 17:12:34
 Re: Cylinder head alignment on four cylinder diese in reply to Bob Santilla, 10-04-2005 07:44:51
yes...they are there only to align the head gasket.. make sure they are in good shape or you will have head gasket problems...the shoulder on the top of the head bolts align the head.
Bob Santilla
10-05-2005 15:49:37
 Re: Cylinder head alignment on four cylinder diese in reply to Jonathan in MA, 10-04-2005 17:12:34
Thank you!!!
Bob
