Hot batteries in JD 2750
Charles Houston
10-04-2005 06:44:27
First set of batteries over heated and failed. Replaced with new and they seem to overheat and have also failed in a very short time. Any help?
Thank you.
CNESLER
10-04-2005 16:24:45
 Re: Hot batteries in JD 2750 in reply to Charles Houston, 10-04-2005 06:44:27
If the rectifier is bad in the alternator it will
ruin battery's in a hurry. Pull the alternator and take it to a shop for testing. Most parts stores will check for free.
CNESLER
Mike M
10-04-2005 07:02:26
Your alt. may be overcharging. Put a voltmeter across your new batteries and see what kinda of readings you get running and shut off.
