JD 440 ICD fan/crank belt
Stephen M. Ferg
10-04-2005 06:18:58
Ahoy- Anyone tell me how to change fan/crank belt on JD 440 ICD. I.e., manuals only discuss fan belt adjustment not replacement. Looks like have to remove front bumper guard/grill, hydraulic pump and radiator/fan. Is there a way to cheat, i.e., can you just pull hydraulic pump to create opening at bottom of crank pulley and either slip belt around fan or remove fan only and install new (adjusting by fan bracket)? Just hoping for a quick fix rather than the $1500 teardown to replace the $5 leaky oil seal (as per my Jag V12 XKE!!!) Thanks in advance. SMF
CPeter
10-04-2005 08:28:47
 Re: JD 440 ICD fan/crank belt in reply to Stephen M. Ferguson, 10-04-2005 06:18:58
Try Fenner Power Twist belting. Stronger that regular V blets and you can thread it in and splice it together.
CPeter
Stephen M. Ferguson
10-11-2005 05:27:10
 Re: JD 440 ICD fan/crank belt in reply to CPeter, 10-04-2005 08:28:47
ahoy CPeter- Thanks for the tip on the PowerTwistPlus belts. Not quite the "No Down Time", easy as 1-2-3 process tho. The segmented link belt keeps the original packaged "set" quite strongly, hard to just "thread" around pulleys. But, with some electric fence wire and baling twine used as a fish, it was doable. Having to thread it thru twice tho was a hassle, first time thru to get approximate length, then remove belt, take out a couple of links per instructions formula, and re-thread. Only ran dozer a few minutes since, but, belt is on, didn't have to tear down machine and hopefully it will stay on. Thanks for the good tip. Still wonder how to do re-belting the "right" way. Can you just remove the hydraulic pump/shaft (looks mighty hard to get to roller pin on shaft, remove belly pan 1st?) and fan blade (ain't much room to get to those bolts and working next to vulnerable rad fins) to put belt on. Or are you still gonna end up taking off grill/front guard/hydrualic pump to re-belt? Anyone? Thanks again. Over and out, SMF
