1960 730 pto clunking
puzzled
10-04-2005 04:01:03
1960 730 diesel pto makes clunking sound when using pto equipment. not all the time ,but it is there..sounds dry and to the top , front of the case..fluids are full , only makes noise when pto is engaged. thanks
Mike M
10-04-2005 17:28:47
 Re: 1960 730 pto clunking in reply to puzzled, 10-04-2005 04:01:03
I have been all through my 720 D and put all bearings and bushings and everything else in that normally wears new. I also have some kinda cluncking noise in my pto drive line after it warms up real good. I never ran it much before I did all this work so I don't know if it was there before or not ? I have no doubt in my mind that if you tear into your tractor you will find lots of stuff needing attention,but you may still have that noise when done. Noises are hard enough to chase down in person yet alone on the internet so yours and mine may be vastly different I don't know.
Aaron S
10-04-2005 07:48:58
Puzzled, I have the same problem on mine depending what PTO equipment I use. I haven"t looked into my problem to much but I have removed the reduction gear cover and checked everything as best I could. I believe the clunking on mine is coming from the bevel gears. Like I said I haven"t looked into it to much and I can"t let the tractor down long enough to dig in but that is where I think I will be headed when I get some time. Aaron
puzzled
10-04-2005 08:14:20
 Re: 1960 730 pto clunking in reply to Aaron S, 10-04-2005 07:48:58
have had it on a sickle mower,and brush hog, and does it just occasional enough that it worries me,,,(breaking gear, or stripping one)just rebuilt it,running yesterday, and had the endplay ing the crank done a couple years ago.and is being painted as we speak.
Aaron S
10-04-2005 11:38:35
 Re: 1960 730 pto clunking in reply to puzzled, 10-04-2005 08:14:20
Puzzled, Mine also only does it occasionally. Sorry I can't be more help. Aaron
