48 G transmission noise
puzzled
10-04-2005 03:54:39
just bought 48 g. runs good, adjusted clutch, went for ride and noticed transmission noise,,ringing or clinking,,,sounds like dry gears...checked trans oil, is nasty brown, but is full. any ideas from you would really be helpfull. thanks
John in IN
10-04-2005 19:37:15
 Re: 48 G transmission noise in reply to puzzled, 10-04-2005 03:54:39
It is recommended to use only Gl-1 gear lube in these tractors. 90 or 140 wt. I think in '48 JD recommended 90 wt. You can get GL-1 at some WalMart stores or check oil supply companies in your area.
Glen in TX
10-04-2005 13:19:38
Drain and flush it out with kerosene or diesel and put in clean oil. You may find water in the bottom when you drain it. Pull cover and take a look at gears, shafts and bearings. Put back in the 85/140 or 140 if you can find it instead of just 80-90.
