Hydraulics on a '46 A
hick
10-03-2005 22:17:30
The plugs that go into the PowerTrol on my '46 A have the hole drilled through the shaft that goes back inside the unit.
When I engage the PTO and clutch and try to run the rock-shaft, the engine lugs down. I remember back on the farm as a youngster seeing plugs for the unit that were solid, not drilled.
Do I need the solid plugs to use the rock-shaft and the drilled plugs for external cylinders?
Or is the cylinder inside the rock-shaft stuck?
That would not surprise me as this tractor, although painted nicely, shows signs of abuse and neglect.
In fact, last week I had to take the hydraulic pump housing off and weld it, it was cracked at the bottom and leaking. And the PTO bearing was very rusty, replaced it also. The pump turns freely and no longer leaks.
MITCHP
10-04-2005 10:26:54
 Re: Hydraulics on a '46 A in reply to hick, 10-03-2005 22:17:30
NOT SURE WHY THE ENGINE IS LUGGING DOWN BUT THOSE PLUGS SHOULD HAVE THE HOLES IN THEM WHEN YOU ARE RUNNING WITHOUT ANYTHING PLUGGED IN AND THE ONES WITH THE HOLES SHOULD BE ATTACHED TO YOUR CYLINDER
