720 3pt
Matt_In
10-03-2005 20:37:53
Going to go look at a 730D this weekend. It doesn't have a 3pt. I have a 720D(that I would sell if I were to buy the 730) I am pretty sure the 3pt off the 720 will work on the 730 is this correct? The 730 has a wf. Are true JD wide fronts square? Thanks
DP
10-04-2005 08:44:52
 Re: 720 3pt in reply to Matt_In, 10-03-2005 20:37:53
Hi Matt. Make sure the 730 has the rockshaft for the three point. If it was just sole off the tractor, everything you nnned you should have. If the 730 was sold new with no three point, there may not even be a rockshaft. Good luck on your venture. Don
720Deere
10-04-2005 06:59:51
They are the exact same parts for the 3pt. The square wide front is the only wide option for a 730 other than the 2 available options for the standards. JD did make a round tube wide front that was used on the first numbered series. It will fit the 730, but is not generally accepted as being "correct".
