Compression on '49 A
nicolas
10-03-2005 20:18:02
I am about to restore my '49 A. It runs pretty good, just needs a paint job mostly. I checked the compression and it has 60 lbs. on both cyl. Is this good, or do I need to look at putting some rings in it while I have it tore down? Thanks, Nick
Nicolas
10-04-2005 20:33:01
 Re: Compression on '49 A in reply to nicolas, 10-03-2005 20:18:02
Forgot to say it is an all fuel tractor.
J. Schwiebert
10-04-2005 08:54:35
Have you ever heard of a cylinder leak down test. Much more accurate than a compression test as far as determining if the valves or rings are at fault. Questions? Is so I will not be near a computer until Sunday.
Dave in SV
10-06-2005 18:02:24
 Re: Compression on '49 A in reply to J. Schwiebert, 10-04-2005 08:54:35
I'd like to hear more about a leak-down test. I'd also like to learn the proper way to conduct a compression test.
Can you enlighten me?
jd b puller
10-08-2005 14:29:27
 Re: Compression on '49 A in reply to Dave in SV, 10-06-2005 18:02:24
Dave: you can buy a leakdown tester at many Auto parts store. They will run from $50-$100. The idea is that you bring the piston to TDC Comp stroke so that both valves are closed. You'll have to find a way to lock down the flywheel. You put the gauge in the spark plug hole just like a compression test, the difference is, instead of the engine generating compression, you are going to put pressurized air in the engine. Listen at the carb. If you hear air, then intake valve is bad. Listen at exhaust, if any air, then exhaust valve is bad. Remove oil filler cap, if there's air coming out of there, then it's either head gasket or rings. A certain amount past the rings is normal and expected. ANY leakage past valves is bad and needs to be corrected. Very useful on lawn mowers with ACR's. Never tried them on a tractor. The piston will attempt to push down when you put the air to it. Not sure how hard it will be to hold the flywheel steady, but if you are at exactly at TDC, there won't be very much force on crank. The more it gets from TDC, the harder it is going to push until it gets to the bottom.
Dave in SV
10-08-2005 15:16:08
 Re: Compression on '49 A in reply to jd b puller, 10-08-2005 14:29:27
Sounds familiar (if not identical) to the way we checked compression in aircraft engines.
Thanks for the detailed explanation!
Mike M
10-04-2005 04:44:07
Did you check it on a warm engine,with choke off and throttle wide open so it gets max. air into it ? Also make sure your gauge is working right. If you only have 60lbs. you may have an all fuel or just bad valves.
PeterE
10-03-2005 21:35:17
Which engine do you have? You should have 75 in an all-fuel, 110 in a gasoline.
hick
10-03-2005 22:09:36
 Re: Compression on '49 A in reply to PeterE, 10-03-2005 21:35:17
Is the 110 for gasoline true for the conversions also? I have a "46 that came out as all-fuel, converted to gasoline. It has 85 PSI.
PeterE
10-04-2005 09:24:27
 Re: Compression on '49 A in reply to hick, 10-03-2005 22:09:36
I'm guessing that it is true for a conversion too, but I don't really know. The chart I have just shows the stock engines, it doesn't say anything in particular about a conversion.
