4230 Oil change mess
R. John Johnson
10-03-2005 10:05:24
Everytime I change the engine oil filter I get a big mess. Oil all down the side of the block and behind the frame rails. Today I tried to catch it with some paper towels, but still had some dribble down past. Does anyone out there have a trick to avoid the mess?
Thanks
John
txgrn
10-04-2005 16:20:07
 Re: 4230 Oil change mess in reply to R. John Johnson, 10-03-2005 10:05:24
Thanks for the heads up. I saw the filter sitting there but have yet to do my first oil change. The thought occurred to me about the slobber during the oil change and sur nuf you verified my concerns.
Will do as suggested and hopefully have a successful change.
Mark
Jason Z in MO
10-03-2005 11:36:45
On the filter mount boss extending from the block is a drain plug. Remove the plug and installed a short pipe nipple, elbow and cap. This will extend beyond the frame rail. Now you can remove the cap and drain the filter before spinning it off. You will have some oil dribble out but not nearly the volume.
txgrn
10-04-2005 16:17:49
 Re: 4230 Oil change mess in reply to Jason Z in MO, 10-03-2005 11:36:45
Is this the 1/2" pipe plug that has a hex allen hole in it and is on the vertical outboard service?
Thanks,
Mark
Jason Z in MO
10-03-2005 14:02:22
oh almost forgot. When you drain the filter it helps to punch a hole with an awl or nail in the top side of the filter canister. Prevents a vacuum lock.
msb
10-03-2005 20:26:34
 Re: 4230 Oil change mess in reply to Jason Z in MO, 10-03-2005 14:02:22
Or go to NAPA and have them make up a hydraulic hose about a foot long with 1/4' pipe fittings.Don't have to worry about a pipe getting knocked off with a hose or twisting off a pipe.I have done both and I like the hose setup better.
