730 Clutch Seal
Texas Denny
10-03-2005 08:10:46
I have a friend with a 730 that is experiencing an oil leak from between the clutch and the block. I assume there is a seal between the clutch and the block. Do these occassionally fail? Are there any tricks or special tools required to change this seal? It sure would help to have an exploded view of this assembly.
Thanks,
Glen in TX
10-03-2005 13:04:28
 Re: 730 Clutch Seal in reply to Texas Denny, 10-03-2005 08:10:46
I also didn't mention that yes there is a seal and gasket on the main bearing and crankshaft behind the clutch also.
Texas Denny
10-03-2005 13:53:45
 Re: 730 Clutch Seal in reply to Glen in TX, 10-03-2005 13:04:28
Thanks, I will go to my John Deere dealer and get info. I've done it with the Ford dealer on my 901 but I guess I'm slow. Didn't think John Deere would be so helpful.
Glen, where are you in Texas? I have a place in Leander and one in Goldthwaite.
Glen in TX
10-03-2005 12:59:41
There is a retaining washer and retainer for the outside roller bearing but not really a felt seal like others had. There is a bushing on inside part of pulley also that if worn too much will let excess oil by. The operating sleeve is suppose to sling the oil off behind the dust shield and it must be mounted properly and not bent up and there is a gasket that goes behind the dust shield. Your JD parts man can print off a exploded view of the parts for you. A I&T JD-16 shop manual available here and from other vendors will also help. Other manuals are available from JD for the 730.
