4020 hydro line question
Nylon
10-03-2005 01:32:20
Right behind the hydraulic cover there are two lines. One goes forward up to the hi pressure hydro pump. The other goes back and up and isn't very long. What is this line? What is its purpose? Is it a return line or supply? If it is a return does is return and go through the filter as a charge? or return to reservoir? There is also a much smaller line that tees into this line coming from behind the dash on the left side. any info on this line?
Thanks,
John
HTR
10-03-2005 17:57:38
 Re: 4020 hydro line question in reply to Nylon, 10-03-2005 01:32:20
If I understand the three lines you are talking about, they go to, and come from the filter relief valve housing. The large line that goes up and back, is the rockshaft piston return line. The small line that goes to the top of the relief valve housing, is the return line from the pressure control valve and steering return line. If all valves are functioning correctly, all oil is filtered and returned to the inlet side of the main pump through the third line that comes from the valve housing. All functions are returned the main pump, none to sump.
Some valves involved in this area, the return oil check valve is in the transmission housing just above the relief valve housing. It has two functions. With the clutch peddle down, transmission pump not turning, it prevents return oil from being forced back through the transmission pump back to sump. It also serves as a oil cooler check valve to prevent oil cooler oil from draining back, through the transmission pump, to sump, when the engine is not running. The valve requires removal of rockshaft housing to service.
There are two valves in the oil filter relief valve housing. An oil filter relief valve, and a surge relief valve. On the original 4010, with the idea that dirty oil was better than none, if the filter was plugged, the relief valve opened and sent dirty transmission pump oil, or return oil, by the filter, and to the main pump. Later it was decided that no oil was better than dirty oil, and there was a up dated valve housing that dumped the oil back to sump. The best I remember, this was a customer pay for modification, so yours may or may not have the newer valve. The surge relief valve prevented spike pressures from damaging the oil filter or oil cooler.
Nylon
10-04-2005 00:38:27
 Re: 4020 hydro line question in reply to HTR, 10-03-2005 17:57:38
Thanks for the specifics. I thought the rockshaft returned internally? Which is why I was wondering what that line was coming from that area. Thanks again guys.
John
HTR
10-03-2005 18:00:19
Oops, I thought you had a 4010. The 4020 had the new valve.
Glen in TX
10-03-2005 13:16:59
Leaks? Problems? Confusion? Hmmmmm mm.
Link
Nylon
10-04-2005 00:45:25
 Re: 4020 hydro line question in reply to Glen in TX, 10-03-2005 13:16:59
Glen,
A while ago I tried to get on the JD site and had lotta troubles. They dont make it easy. Once I got there I found that they don't go back to 1968. Or do they with some other method? Any info would be handy. I haven't actually signed up since finding that there wasn't support.
John
Glen in TX
10-04-2005 13:04:52
 Re: 4020 hydro line question in reply to Nylon, 10-04-2005 00:45:25
You may have to register for it to work easier? It will go to parts before 1975 and 1968 as I have acessed several times there for 5010, 4010, 2510 and 2010 and 1010 tracors. It does not have info on the 2 cylinders though. Guess they want to make you pay for that. Your dealer has acess to the 2 cylinders on there though and can print things out for you also. You don't have to buy parts through it and can just search. Our local dealer doesn't use it for orders and wants us to call it in to them anyway. Once you do get it to work the prices there will be different than your dealer somewhat also and if it shows invalid I would still check with your dealer or several other dealers also just to be sure. I have had parts turn up available when the site said invalid. Once you get it to work enter part numbers there for searches or click on the parts book and then can click model search and enter the tractor model 4020 and it should bring up the parts manuals for it. On the publications site enter your model number and click the exact match box for find it easier.
