Choosing a John Deere Tractor
Andre' E. Newel
10-02-2005 19:15:56
I am in the process of buying a used tractor with a diesel engine. I am looking for a Deere that is compatible to the Massey 135. I will use it to bush-hog, disk, and move hay. I am debating between the JD 820, 1020, and a 2040. Which is the best selection for a five or six foot attachments? Also if the scv remote is connected to the three-point hitch hydraulic, can they both work at the same time?
Thanks,
Andre'
mitchp
10-03-2005 06:23:15
 Re: Choosing a John Deere Tractor in reply to Andre' E. Newell, 10-02-2005 19:15:56
hey andre, if you get a 2040 or a 2240 you'll be able to use your 3 point and SCV outlets too. you'll have 2 outlets at the back and a seperate lever too. i would go with the 2040 esp if you need to use it in the winter, these tended to start better in the cold. my uncles neighbor has a 2240 with way over 12K hours on it, been a really good tractor for the work its had to do.
Mike M
10-03-2005 05:31:25
If I understand you correctly ? I put one of those on a 1020 it was just to raise a mower conditioner and it was just one outlet. You had to fasten the 3pt arms up and then use the rockshaft lever to work it. So on this set up you were not to use both at the same time. There was another more expensive option that had it's own seperate valve and lever and this one you can use independantly of the 3pt. or both at once if needed.
