Hydraulic pump or stroke control valve problem JD
Colby Martin
10-01-2005 23:05:21
New to the board... I just bought a 4230,,, it has blown two hoses and a fitting on the rearend off... I believe someone has messed with the prssure setting on th pump control valve and it is way too high,,, it is leaking and needs to be rebuilt anyway,,,, the pump looks like it has been rebuitt not too long ago,, this maybe my problem.... Does anyone know who can(company or person) rebuild the pump and stroke control valve unit and set or check the proper pressure?????
Thanks Colby
Any advice would be help full..
DeereGuy
10-05-2005 18:03:05
 Re: Hydraulic pump or stroke control valve problem in reply to Colby Martin, 10-01-2005 23:05:21
I just went through a similar situation on a 4010, I read the manual, and some folks on here got me through it. I bought a high pressure hydraulic guage and adjusted the pressure myself. The key is having the right fittings for the guage (I think they are around $20 for the guage and a couple $ for the fittings - buy the fittings from local hardware store once you have the guage and know the site of the pressure testing port) and knowing where to hook up the guage, and then where to adjust the pressure. Here is where I bought my guage: http://www.findtoolsnow.com/hydraulic-guage.html
You can cut and paste the link or just use the one at the bottom of this reply.
Be sure you get a gauge that goes higher than 3,000 I would say.
If it is only a matter of adjusting the pressure down you can likely do it yourself if you have an IT manual and guage. Removing and rebuilding the pump is a much bigger job. Good luck!
gwece
10-02-2005 08:09:15
Your local Deere dealer should be able to dispatch a mechanic and service truck to your place and check/adjust the pump output pressure. Their shop should also be able to rebuild the main pump if needed. Be sure to price a rebuilt pump from other sources (Worthington Ag Parts, etc.) before you authorize a dealer rebuild though. I went though this with a 4010. Seems like a paid around $300 for a service call/pressure check. Deere wanted about $1400 for a deere rebuilt pump. Bought one from Worthington Ag for a little over $1000 if memory serves.
G/MAN
10-02-2005 13:47:32
 Re: Hydraulic pump or stroke control valve problem in reply to gwece, 10-02-2005 08:09:15
The price for the Deere pump was more than likely for a brand new pump, not rebuilt. There are two pumps shown for the 4010 depending on serial number. One is $1500 new list, the other $1630. A lot of the prices have gone up some recently, so a new one probably was $1400 a few months or years ago. I think places like Worthington bank on the fact that many guys will automatically assume that a new OEM part will be WAY higher, when in many cases they're not. Would you have paid an extra $400 for a brand-new pump? I'd also say that you may have gotten taken to town on that service call. Checking standby pressure and adjusting it if necessary is a process that takes minutes, not hours. It was probably a little more involved on your 4010 though, as the newer tractors (30-series and up) usually have a dedicated test port with a quick-connect on it for checking the standby pressure. With gauge and long hose or digital pressure gauge, you can lay under the tractor up front and adjust the screw while watching the gauge.
